96 accord clunking noise in passenger tire
Old Mar 17, 2014 | 11:17 AM
j_fluent's Avatar
Default 96 accord clunking noise in passenger tire
Whenever im driving at low speeds the passenger tie is very wobbley and makes clunkling sounds. Ive changed all my suspension, ball joints, cv axles, sway bar links, wheel bearings but the sounds just recently started. My car is slammed so im not sure if that affects anything but, any help?
Old Mar 17, 2014 | 11:26 AM
ej7attack's Avatar
Default Re: 96 accord clunking noise in passenger tire
inner and outer tie rods? being slammed has some effect im sure.
inner tie rods usual never get replaced and if you did indeed change out them other components that should narrow it down.
Old Mar 17, 2014 | 11:30 AM
j_fluent's Avatar
well now that you said that, it does feel a bit loose. can they be tightened or does that mean the steering rack is bad?
Old Mar 17, 2014 | 03:36 PM
ej7attack's Avatar
they cannot be tightened only replaced if bad. they screw into the rack. go to google images and type in accord inner tie rod. there is a ball joint on the inner tie rod and they do go bad specially for an older car.
Old Mar 17, 2014 | 07:17 PM
j_fluent's Avatar
Okay gotcha. Makes sense. I'll pick some tie rods up tomorrow morning then. Hopefully it solves the problem. I wouldn't think it'd be the rack because it's only one side. But I'm knowledgeable about motor work, suspension and chassis parts aren't my thing. Thanks for the help. I'll get back with results
Old Mar 18, 2014 | 01:32 PM
ej7attack's Avatar
also check lower control arm bushings.
Old May 6, 2014 | 10:58 AM
j_fluent's Avatar
well guys, the day I picked up the parts and was on my way to my shop to put them in, i got in a wreck and totaled my car. So we will never know what the problem was.
delljoey
Dec 4, 2012 05:30 PM
bark3rk20
Suspension & Brakes
Jun 30, 2011 05:32 PM
BrayzieEF9
May 3, 2010 06:55 AM
Scinonfi
Jun 18, 2008 06:19 AM
black_cap
Oct 9, 2004 03:18 AM
