Transmission & Drivetrain Gearboxes, Differentials, Clutches
H22 Cluch in F20A4 Engine
Old Mar 17, 2014 | 02:01 AM
TM-20-FOX's Avatar
Default H22 Cluch in F20A4 Engine
Hy , please help me with this , im trying to find a cluch kit stage 1 for my car (Honda Prelude 2.0i , 133 HP , 5th gen , year 1999 , engine type F20A4 , but it seems that i cant find one , i find only for H22 , on this forum i read that "
flyrod
iTrader Rating: (0)
Re: Flywheel in Prelude BB3 F20a4 engine (Japanpower)
Quote:
Oiginally Posted by Japanpower
and the flywheels, too ??
The H-series crankshafts have a pin that mates to a hole in the flywheel to clock the flywheel. This is so that the timing marks on it can be used. Most of the F-series engines have these marks on the accessory pulley, and their cranks/flywheels don't have the pin. In this case the flywheel can be installed in any of 8 positions (it doesn't matter). So yes, they are interchangeable, but depending on how you are mixing and matching parts you might need to drill a hole or grind off a pin. In this case, be careful about using the flywheel marks to set timing. Good luck.
__________________
Stuff for sale: K20A longblock Hondata Stage 4B Chipped P28's
Lots of 4th Gen Prelude stuff: STR fuel rail NIB, Si Brakes, ABS
H22 cams, etc.
BUT IM STIIL NOT SURE , CAN I PLEASE GET AN ANSWER FROM SOMEONE WHO KNOWS FOR SURE . THANKYOU.
Boosthead
Aug 3, 2009 05:50 AM
BB4-Japanpower
Nov 2, 2005 09:53 AM
Jago
Sep 22, 2003 04:41 AM
