04 RSX Type - S Code: P2647 (rocker arms actuator a - bank 1 stuck on) PLEASE HELP !
Old Mar 16, 2014 | 12:34 AM
Mengo Lor's Avatar
Default 04 RSX Type - S Code: P2647 (rocker arms actuator a - bank 1 stuck on) PLEASE HELP !
PLEASE HELP !
i own a 04 rsx type-s nd my CEL came up saying code : p2647 .
-my oil are good
i did some research nd people said its the vtec oil pressure
my CEL comeson on & off . when CEL is on i cant ram its above 4 or it start shaking . what do i need to do ? please ASAP !
Old Mar 16, 2014 | 11:43 AM
Mengo Lor's Avatar
Default Re: 04 RSX Type - S Code: P2647 (rocker arms actuator a - bank 1 stuck on) PLEASE HEL
help !
Old Mar 25, 2014 | 03:52 PM
stereotypeit's Avatar
I'm in this same boat... but I own a 05' Si, K20A3 and I too received the P2647... everything I've seen so far is oil pressure related... someone suggested changing the oil if it has been sitting for awhile... done... still comes on...and off... and on again... just like you, when the light is on, the motor won't rev past 4k rpm... rev limiter stops me dead, lags you might say... I'm still searching, and asking... i'll repeat what I hear at you... also I just ordered a OBD II scanner so I can stop having the auto zone guys pull the same code for me... good luck
Old Apr 1, 2014 | 03:13 PM
Mengo Lor's Avatar
Aye man ! UPDATE ! i fixed my problem ! bought the whole vtec assy. solenoid kit which cost around $150. i prefer you buying the whole vtec assy. solenoid kit rather than the pressure switch & filter. its easy to fix it too. just take out your old vtec solenoid nd install the new one in. after that it should be running fine cause my did . HOPE IT HELP :D.
should look like that the whole assy.
Old Apr 4, 2014 | 09:40 AM
where did you get your assy. from?
Old Apr 7, 2014 | 01:51 PM
Mengo Lor's Avatar
http://www.acuraexpressparts.com/
look for your year model type .
than the code # should be 15810-PRB-A03
Old Apr 7, 2014 | 05:15 PM
ok... I show a 15810-RAA-A03 spool valve assy. sound right... mine is $54.69 cheaper than yours... weird... cause everywhere I've looked before you gave me that link showed one VTEC solenoid(spool valve) for both K20A2, K20A3... and given that your driving a A2, and I'm in an A3... that apparently makes a difference... good looking out dude, thanks a lot
Old Apr 17, 2014 | 03:51 PM
yep... solenoid changed out, problem fixed
Predator220
Sep 7, 2016 02:12 PM
harshhatch1187
Oct 12, 2004 05:46 PM
JohnnyBoy
Dec 6, 2001 08:54 PM
pstreck
Sep 7, 2001 10:31 AM
