turbocharged 93 prelude spark plug questions
Old Mar 15, 2014 | 10:12 PM
range hadies's Avatar
Default turbocharged 93 prelude spark plug questions
i did a good amount of research and got varied answers but eventually went with ngk coppers gapped to .30
the prelude starts cutting out when it hits anything above 10psi of boost.
the spark plugs i had on before i couldnt remember and got fried so i had to change them.
a tuner in the area says he uses a saab turbo spark plugs on hondas.
are hondas able to take a saab spark plug? and if so is it a good idea?
Old Mar 16, 2014 | 05:33 AM
brixcivic's Avatar
Default Re: turbocharged 93 prelude spark plug questions
ngk is the way to go the degree of the plug and the gap all depends on your setup
Old Mar 16, 2014 | 07:13 PM
but what i was wondering was if a saab turbo spark plug would work in the prelude?
Old Mar 17, 2014 | 08:06 AM
snobordboy's Avatar
Moderator
If it is the same spec, who knows. The NGK coppers in "7" heat range should eb what you use. BRK7E if I remember right.
Old Mar 17, 2014 | 05:58 PM
the question is not the heat range ect, is if a saab spark plug has the same thread pattern and would actually work regardless of type.
Old Mar 18, 2014 | 07:12 AM
snobordboy's Avatar
Moderator
Holy christ, go to autozone, open their little book and see what plugs are compatible with what cars. There are seriously 2 different threads for automotive spark plugs, but there are many different heat ranges, gaps, lengths etc, that is what your differences will be.
Old Mar 18, 2014 | 12:08 PM
98vtec's Avatar
moderator emeritus
right there.
they come gapped to .030". but check double check them. I run those in my hatch.
If you already have the plugs gapped correctly, my next question is what spark plug wires are you running?
Old Mar 18, 2014 | 01:32 PM
im running i have ngk coppers rated at 7 gapped at .30 they are called ngk BKR7E-11.
im pretty sure my wires are just standard napa wires. same for distrubitor and rotor.
Old Mar 18, 2014 | 02:00 PM
snobordboy's Avatar
Moderator
Ok those are the plugs that most would say to use in there.
Time for more questions:
What fuel are you on.
What tuning system.
Who tuned it.
What injector size, and duty cycle are you at.
Do you have a wideband on the car, and the capability to log it if so?
And I am from Golden, so I know the area well!
Old Mar 18, 2014 | 05:43 PM
untuned 550 injectors 225 fuel pump no wideband.
it ran perfectly fine before but it sat for winter and now that its summer i tried starting it up and it just started taking a dump and refuses to act right.
i thought it was just bad fuel but i drained and puit new fuel in and its still acting the same
Old Mar 19, 2014 | 04:57 AM
98vtec's Avatar
moderator emeritus
no tuning, bigger injectors.....come on man use your head!!!!
get it tuned. NEVER drive an engine untuned like this. Muchless put it into boost!!
Contact a tuner ASAP
Old Mar 19, 2014 | 06:25 AM
i know i know dont sham me just yet lol, i was planning on doing it but its just running like crap and im afrade to take it anywere till the problem is fixed.
its not only when boosting i found out if i just keep it at a certin rpm while idle it starts popping and chopping so its not just from boost its actually when i get above 4k rpm without boost aswell
Old Mar 19, 2014 | 06:56 AM
98vtec's Avatar
moderator emeritus
its running like crap because you are running injectors twice as big as the stock ecu thinks they are. You are dumping fuel into the cylinders which cant be completely burned causing fuel to puddle on top of the piston.
id be very weary of this as well because if you do this long enough, you can fuel wash the cylinder walls of oil and burn up your piston rings causing you to burn oil and lose power and ultimately requiring a rebuild
Old Mar 19, 2014 | 08:37 AM
snobordboy's Avatar
Moderator
Call up PFI in Longmont, they should be able to give you some advice, and/ or get you in for a tune.
Old Mar 20, 2014 | 06:59 AM
figured it out, fuel filter was clogged.
i knew what i was doing and what i was talking about i mean no offense but none of you were any help just making accusations but ultimately had no idea what was going on.
i didnt need 2nd opinions about tuning i just wanted my simple answer solved and got off track.
i am done using this site and wish everyone the best of luck
Old Mar 20, 2014 | 07:43 AM
bamaland601's Avatar
checking a fuel filter is something you should have been tried when you said you drained the gas. dont blame us for your mistake.
you asked of spark plugs totally opposite of a fuel filter buddy.
you'll be back
Old Mar 20, 2014 | 10:19 AM
98vtec's Avatar
moderator emeritus
and your name is now in my notes. good luck with future help here. might want to change your attitude.
unknown2
Oct 10, 2006 11:59 AM
nickolas388
Oct 26, 2005 08:01 PM
RACEPAK
Sep 21, 2005 04:08 AM
