FS: DA Integra parts, ACT, Exedy, Fidanza, Mounts + More
Have to clean out all of the leftover parts from the old setup. Everything here is in good working order. Parts located in Glen Burnie, MD
ACT 6220110 Race clutch disk, Installed 4/12. Roughly 1000 miles. Firm engagement, not quite on/off switch but definitely not stock feel. Rated at 280 ft/lbs of torque. will fit all 92+ B-Series transmissions, cable and hydro. $120
OBD-1 PR4 $80
Trans - Engine Brackets $25
Rear T-Bracket '91 Integra SOLD
Half-shaft out of '91 Integra SOLD
Crank Pulley '91 Integra SOLD
JDM XSi transmission, with LS 5th gear set SOLD
OEM Axle out of '91 Integra SOLD
Exedy Stage 1 Clutch Pressure plate SOLD
Fidanza Flywheel 7.5 lbs SOLD
Front and Rear motor mounts with energy suspension inserts SOLD
OBD-1 PR4 $80
JDMAppeal
May 6, 2014 04:59 PM
TeamNextGenChris
Aug 8, 2008 03:15 AM
TeamNextGenChris
Aug 8, 2008 03:13 AM
