94 civic ex coupe - which front bumper cover do I buy?
Old Mar 15, 2014 | 08:43 AM
white civic 94's Avatar
Default 94 civic ex coupe - which front bumper cover do I buy?
Hi to all,
Question ,
Have a 94 civic 2d ex all stock no mods
Been trying to find front bumper cover , have purchased several aftermarket bumpers , & factory oem bumper , all ordered per vin# , none of these bumper covers will fit , the frame/front end has no damage or repair done , bumpers should fit right up , but like the mold for this incorrect , running out of options, all replacement bumpers look exactly like original but replacements have not been tall enough to bolt up ( about 3-4" to short) but width from fender to fender is ok , not finding any info on this issue anywhere on web & dealer says that he is out of options , any recommendation for how to resolve this issue would be very helpful
Thanks to all
Old Mar 15, 2014 | 09:21 AM
that_boy_sammy's Avatar
Default Re: 94 civic ex, f bumper?
Take a pic of it so we can have a more clear idea of where its not fitting. The way I do it is start in the middle(grill) area snap those clips in, then do the sides. You're probably not lining something up right.
Old Mar 15, 2014 | 07:18 PM
Thanks for reply,
Will try to upload pics, will have to purchase another bumper cover as I have returned them all,
For the grill (CLIPS) there is none of these on this model ,just 5 screws on top of cover & 2 under car on bottom of cover then few on each side for fenders ,
To give an idea , there is a styro foam block that fits between cover & front frame , if styro foam is mounted on frame ,the cover has a center stand off that should go under this styrofoam , but hitting dead center of styro block, so cover will not lay in correctly , also when cover is installed with top screws in place ,the bottom of cover lands about 3" high into radiator area , as where it should go under neath of bottom frame , like the space between the tag bolts & grill ,on cover need to be 3" taller when this cover is molded , again only two different covers where used on this year , & i have correct cover ( looks like the one that was from factory ) but even the OEM from Honda is doing same problem , so all covers that where purchased being from factory or aftermarket companies have had the exact fitment issues , the Honda dealer /parts manager has no remedies for this issue either , but took car to dealer to prove that it was not fitting correctly , after the seen this in person they where lost , been trying to find a cover in salvage yard as to get an original from that year , but no luck , just can't believe that I cannot find anything on this anywhere ,
PS; let me ad that when one of the covers I returned to PARTSTRAIN the person on phone said that all the covers that been sold where returned as well , but they forgot to mention this when ordering , go figure ,
Also do not have the original one, like a dummy I tossed it out after new cover was delivered , but was to install at later date , I myself removed original cover , so do know how to reinstall , not very difficult if the cover would just fit correctly
Maybe I should start looking for some type of race/sporty like bumper cover like as if the car had mods done to it? Emmisions are due , would hate to take off road for this , but police in my area are brutal about no bumpers on cars
Thanks again
Old Mar 16, 2014 | 04:29 AM
RichCMemphis's Avatar
Where are you buying the bumpers from and second, is the foam aftermarket or oem? I've had problems with aftermarket absorbers being too big.
Old Mar 17, 2014 | 08:22 AM
Buying bumper covers from Honda factory dealer , foam is original oem
Frozti
Mar 30, 2017 09:21 PM
pcastror
Honda Civic (2006 - 2015)
22
Nov 10, 2013 05:30 PM
gabriel0830
Paint and Body
Feb 15, 2013 05:14 AM
diyer
Aug 13, 2004 05:28 PM
