93 honda prelude abs
your abs unit might be faulty. but if so, check your wheel sensors to the calipers (if equipped). Normally a cut, stretched, bad/lost connection or burnt wire is always the case. If you have a Scan Tool, that can pull up the ABS module, you can reprogram & reset.
There's 2 wire harness below your dash (beside gas pedal) plugged into a holster behind the center console... thinka bout where your right foot rests when you're driving, the hump beside your foot .. on top of that just against the inside of the plastic part that eventually wraps up and overs the stereo, on the floor.
One is for ECU one is for ABS, get a paper clip, bend it into a U shape, short out the jumper with the car NOT started, but in ignition II .. the ABS light on the dash will blink.
Do some searching for specifics, I'm going off memory from years ago.. I have a new lude that I need to pull the abs code for as well so if you find the info please post them
Pull the code and see what it says.
Just get to the blue connector and jump the connector and the ABS light will flash a code.
Here is the list for the codes. It usually does a series of quick flashes, a pause, and then another series of quick flashes.
Codes:
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Codes:
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Did you watch it the whole time?
It'll go in sequence and repeat. Again, I'm going off of memory and just posted what i had found on other forums, google's your friend
http://www.preludeonline.com/f61/tho...-light-204346/
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
http://codes.rennacs.com/plugins/Hon...RE96-Ascot.php - click continue on this one, then enter your code 2 ... shows parking brake something?
you cant just say fixed and thanks, you have to tell us in detail what you did so the next guy can come on and read this thread and be like..oh yea right on!
Well I got code one I took off my abs pump by the 3 nuts holding it got all the break lines off then took it out took the motor apart cleaned up everything with sand paper made sure it goes in and out pretty freely then I bled the pump made sure all the air is out then I put it all back together and bled all 4 brakes then I took out the red fuse with a 10 on it and diss connected the battery to reset it then boom no more abs light
stackz
Feb 17, 2012 07:12 AM
