exhaust hanger bushings
Old Mar 14, 2014 | 03:31 PM
ej1b18c1's Avatar
Default exhaust hanger bushings
1994 civic ex coupe
2 1/2 catback custom
Noticed today that my exhaust has a little more play then I like,(wobbles) and that my exhaust hanger bushings are pretty old and still the original bushings. So, why not replace them.
What brand should I replace them with? I believe I have a total of 4 and are they all the same size?
I heard the hard rubber Cusco bushings are really good, or should I stick with OEM or any other brand recommended?
http://www.kseriesparts.com/cr/CUS1-A160-RM003B.html
This site is just a reference and can probably get them cheaper.
Old Mar 14, 2014 | 03:54 PM
B_Swapped93's Avatar
Default Re: exhaust hanger bushings
that's pretty cheap....part stores probs have them for less tho.
Old Mar 14, 2014 | 05:30 PM
tony_2018's Avatar
Fish Twig
OEM or find them at a junkyard or parts store. I usually go junkyard hopping at pull a part, enter for 2 dollars collect all the 10mm bolts I can hold and junk no one thinks of like harness plugs that still look good with no corossion, stuff like that.
Old Mar 14, 2014 | 06:11 PM
belairbrian's Avatar
OEM, or Walker are the ones I've used. Both worked well.
Old Mar 14, 2014 | 07:23 PM
ej1b18c1's Avatar
Ok, I'm leaning towards oem since they've lasted this long already. The only thing that I question is the weight of the exhaust vs stock exhaust piping causing premature wear and more slack compared to the hard rubber.
I have 4 that I can remember, 2 holding by shifter, and 2 where the muffler is at. Are they all the same size from factory? I'm getting mixed answers on that.
Thanks guys.
Old Mar 14, 2014 | 07:26 PM
my 20 year old ones are holding a 3'' K-teller and they haven't ripped yet the weight difference isn't worth noting. the rears are a bit smaller but not that it'll make a difference.
Old Mar 14, 2014 | 10:29 PM
ej1b18c1's Avatar
^^ That's the reason I want to stick with oem. The only reason I'm considering Cusco is because of how sturdy they are compared to soft rubber. I just don't want the exhaust to wobble or move. I might just buy both and compare since they're not that much.
Old Mar 15, 2014 | 06:23 AM
MoreCowbells's Avatar
The walker ones I bought at rockauto.com were pretty sturdy/good quality for the price. Might be something to consider if you want to save a few.
Old Mar 15, 2014 | 08:08 AM
ej1b18c1's Avatar
^^ Thanks, good to know and actually might consider because of how cheap it is.
DelSolMarine
Apr 18, 2012 11:08 PM
K-Spec
Apr 23, 2006 10:37 AM
Mortonbaychestnut
Oct 5, 2005 08:20 AM
clarkekent13
Suspension & Brakes
Jul 25, 2005 07:57 PM
