Radio/Climate Control lights not working.
Old Mar 14, 2014 | 01:38 PM
bromas203's Avatar
Default Radio/Climate Control lights not working.
Hello HT,
Let me start by saying I tried to google and search for a solution to my problem but did not find anything specific to my problem.
I bought my car over 6 months ago, 96 Ex coupe, and my climate control and radio lights would light up perfectly when i turned my lights on.
About 4 months ago the radio lights started to flicker and then stopping working all together. Radio still works.
The same thing happened to my climate control lights 2 months ago. The climate control works, but only on fan speed 3/4. 1 and 2 do not activate.
I was wondering if there was a specific set of wires i should be checking or anything else to look for? where should i be looking to correct this issue.
I also checked all my fuses and none of them were blown.
Any help is appreciated. Thank you.
Old Mar 14, 2014 | 04:21 PM
that_boy_sammy's Avatar
Default Re: Radio/Climate Control lights not working.
Do your cluster lights work? If not then its your dimmer switch. If the cluster lights do work pull out the bezel(the thingy the radio is mounted to) and make sure all the connectors are plugged in, in the back of the unit. There's like 3 or 4 connectors.
Old Mar 14, 2014 | 05:18 PM
bromas203's Avatar
My cluster lights work fine,dimmer gauge works, tach, speedo, almost all dash warning lights work, only one i know that doesn't work is the Low Fuel. Ill try and pull the bezel out tomorrow and check my connections. Thanks.
VtecCivic93
18
Jul 24, 2009 05:31 AM
HondaHemi
May 12, 2005 09:05 PM
B_Something
May 24, 2004 09:06 AM
00fbp
Dec 6, 2002 03:03 PM
