b20 swap misfire
Old Mar 13, 2014 | 08:17 PM
SpeedOFsmell's Avatar
Default b20 swap misfire
Ive been chasing a misfire in my 1997 b20b swap in my 90 si, and finally found that if i pull the vac hose from the FPR and plug it, the misfire seems to go away. it's running a pr4 ecu (obd0) and apparently its lean. really misses at wot at higher rpms even with a wide open FPR. I chased all the ignition possibilities and comp tested 180 psi across the board.
anyone ever seen a pr4 cause a lean condition this bad? just the wrong injector pulse width?
i plan to go obd1 with a socketed ecu sometime this year, but what ecu can i buy for now to hold me over until im ready to dump money on a distributor, etc? has to stay obd0 for now.
Old Mar 14, 2014 | 06:38 PM
Default Re: b20 swap misfire
Fixed. It was a plugged injector bucket filter on cylinder 3.
woodenchef
Dec 25, 2012 01:17 PM
allmotorCRX.
13
Jun 12, 2011 06:46 PM
fndbt
Oct 16, 2009 09:50 AM
RA122324
24
May 13, 2006 11:10 AM
SuperCivic
11
Jul 29, 2002 03:00 PM
