99 Civic Accessory Socket Fuse - 10a to 15a?
Old Mar 13, 2014 | 11:40 AM
pnwcivic's Avatar
Default 99 Civic Accessory Socket Fuse - 10a to 15a?
After blowing the 10 amp fuse for the accessory socket with a new accessory charger I bought, I discovered that the accessory charger wants 15 amps. Hence the blown fuse.
The manual tells me to use a 10 amp fuse for the accessory socket in my 99 Civic. I'm wondering if it will be OK to use a 15 amp fuse so I can use the accessory charger I bought, or if I absolutely need to stick to the 10 amp recommendation and return my accessory charger!
Any advice would be welcomed and appreciated.
Old Mar 13, 2014 | 01:45 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 99 Civic Accessory Socket Fuse - 10a to 15a?
That number is not a suggestion. That line is rated 10amp for a reason. Use a larger fuse if you want to risk melting the wires and catching your car on fire.
imadigitalgod
Audio / Security / Video
Jul 7, 2007 04:59 PM
skata89
Jul 24, 2006 11:48 AM
Bucktown
Mar 8, 2004 06:11 PM
specv5150
Feb 23, 2004 05:26 AM
Zappas
Jul 11, 2002 10:22 AM
