OEM Rubber Mounts for B16?
Old Mar 13, 2014 | 09:14 AM
7rrivera7's Avatar
Default OEM Rubber Mounts for B16?
Are OEM rubber mounts available for a B16 swap into an EF chassis? I've used Place Racing, Innovative and Hasports mounts and they all vibrant too much for my liking - even the softer ones.
I know the CRX came with a factory B16 in Japan but need to know if an equivalent is available in the US. Thanks!
Old Mar 13, 2014 | 10:08 AM
Freemananana's Avatar
Default Re: OEM Rubber Mounts for B16?
You can get the cheapest steel mounts with 65A rubber inserts from innovative. That or use stock B-series mounts and reweld the brackets on your chassis. I'm not sure what you mean by vibrate too much. My B16 swap in my EF with billet HASport mounts and black inserts hardly vibrates at all under load or at idle.
Old Mar 13, 2014 | 10:40 AM
Deetz's Avatar
Crazy Honda Guy
The factory crx and civic models in Japan had different sub-frames that usdm cars, those mount do NOT work.
The easiest solution to your vibration issue would be bring the idle up a couple rpm, it makes a big difference
acmoc
11
Dec 7, 2008 04:07 PM
svacca1
Nov 16, 2007 08:49 PM
D3U1LT
Sep 15, 2006 09:54 PM
