Power Steering Problem
Old Mar 12, 2014 | 10:19 AM
afnan's Avatar
Default Power Steering Problem
My transmission was changed and it did not came with VSS sensor which assisted in speed sensitive control. Rite now my pump works partially. When car is off its too hard and when its running its softer but not as it should be.
My current transmission is missing following part and the two pipes used to connect are bypassed by U shaped pipe
Question is if i find and install the part would it soften steering further ?
Old Mar 12, 2014 | 07:40 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Power Steering Problem
Yes, you need that sensor to maintain the correct operation of your power steering boost assist.
Old Mar 13, 2014 | 04:04 AM
afnan's Avatar
If those two pipes have been bypassed by U shaped pipe which means soften the steering maximum? with bypassed my car still have partial working system. Not too much soft.
ajmitch51
May 5, 2014 05:58 AM
clewis152
Aug 7, 2012 05:01 PM
Fred Demara
Jan 4, 2012 04:33 AM
