question..ITR sway bar on EM1
Old Mar 12, 2014 | 08:42 AM
ribal_gh's Avatar
Default question..ITR sway bar on EM1
hello,
I am planning to upgrade my rear sway bar on my civic si 00 so i want to order an ITR sway bar.
I read that that D brackets of the ITR does not fit my car.
So any idea what bracket should i get?
(An ASR subframe will used)
Old Mar 12, 2014 | 08:46 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: question..ITR sway bar on EM1
Originally Posted by ribal_gh
hello,
Pretty sure the D brackets fit just fine. They did on my EM1. The sway bar links have to be swapped over...and you need a bushing for that.
I think you can either buy a bushing at a hardware store or order a CTR bar.
Someone correct me if I'm wrong. I remember having to use bushings to go into the eyelets of the sway bar.
Old Mar 12, 2014 | 09:16 AM
ribal_gh's Avatar
so the ITR D brackets will fit fine!
I will order bushings at the same time for the 22mm bar.
Is there any other parts that i should take into consideration for correct fitment?
Old Mar 12, 2014 | 09:32 AM
tony_2018's Avatar
Fish Twig
Yes D bracket will fit, just make sure you have a good reinforcement bar.
B serious's Avatar
I was talking about the bushings that go into the eyelets. Like...where the links fasten to. Those might come with the ASR kit though. They came with my beaks kit. I remember having to replace the bushings for the end links to work.
I used ITR D brackets though.
Hopefully someone can provide more insight.
Old Mar 15, 2014 | 01:18 AM
ribal_gh's Avatar
So after inserting the bushings and collars the sway bar holes will look like that.
I was wondering if my stock si end links will still fit because the holes looks much widders than the stock 13 mm sway bar!
any idea ?
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
giomfe
Suspension & Brakes
Aug 10, 2007 09:36 AM
dgdarien
10
Mar 30, 2003 01:09 PM
mamaboy
Nov 17, 2001 06:49 AM
