Suspension & Brakes Theory, alignment, spring rates....
01 civic ex sedan koni str t
Old Mar 12, 2014 | 05:34 AM
rta60460's Avatar
Default 01 civic ex sedan koni str t
I recently purchased some koni str t and am looking to either get the tein s tech ska22 (everywhere I look tells me a different spring rate for some reason)or megan springs spring rates of 280F and 230R...I know the koni str t cant handle high spring rates and aren't recommended to drop car under 1.5" so I am staying within that range....Looking for opinions on which of these two springs to choose....also I plan on doing this work myself and have never attempted it so can anyone tell me if there are any other parts I will need to do this job? like mounts or anything of any sorts? I have no Idea how the strut and springs go together as far as what I might have to use off the old struts and what is recommended to just replace...I plan on using youtube for instructions on how to do the job..with youtube and forums like this I can do just about anything lol...thanks for any help or advice in advance..
Old Mar 12, 2014 | 07:15 AM
rta60460's Avatar
Default Re: 01 civic ex sedan koni str t
well according to tein website they are 157 front and 291 rear..why are all other springs more in front an less in rear but these are opposite?
Old Mar 13, 2014 | 04:48 PM
90_EX_Civic's Avatar
the tein's you are looking at might be running a spring setup the same as a ep3. hence the high rear spring rate
Jar-Head23
Suspension & Brakes
Jun 28, 2009 11:15 AM
GSRintegra_Bob
Suspension & Brakes
Jan 23, 2006 06:04 PM
SE7EN3S
Suspension & Brakes
Aug 30, 2005 02:58 PM
Tony R
Apr 2, 2004 05:56 AM
Rice Ball
13
May 19, 2003 11:09 AM
