Difference of si map sensor and dx?
Does any one know if there is a difference?
For example, can you use an si map (pm6) onto a d15b2 engine setup?
And can you use a dx map( pm5) into a d16a6 engine setup?
The MAP sensor should be fine. I ran the same MAP sensor on a D15B1 as I did on a B16A as I did with a turbo and I've seen people use them for everything in between. Z6, Y8, A6, GSR, ect. Should be fine.
CRXguy_88
Jul 11, 2010 09:10 PM
KinGClowN
Jul 14, 2003 03:40 PM
89dxhunchback
Jul 9, 2002 09:37 AM
