is this a mini me?
Old Mar 11, 2014 | 09:29 AM
BudWheel's Avatar
Default is this a mini me?
I may have been screwed by my seller for not knowing all the info. I hate a freaking liar. I have a d16y7 head on a b15b2 block. Now here comes the bad news I'm guessing.
Old Mar 11, 2014 | 09:35 AM
B_Swapped93's Avatar
Default Re: is this a mini me?
That's a non-VTEC head.... so not a "mini-me" not his fault you didn't look at the head for a vtec solenoid.
Fliptard's Avatar
no, a mini me is basically a Non-vtec block with a vtec head. Others will say it's a d15 block and d16 head.
Old Mar 11, 2014 | 09:49 AM
BudWheel's Avatar
Well thanks for the bad news as I suspected
Old Mar 11, 2014 | 09:58 AM
BudWheel's Avatar
Ok it is not a mini me are there any advantages or disadvantage for putting this newer head on an older block? Also will the stock 93 ecu work with this setup? I'm guessing I also need the cam gear from the y7?
Old Mar 11, 2014 | 10:43 AM
import-tooner's Avatar
What year and model is the civic that this engine is in?
Old Mar 11, 2014 | 10:52 AM
BudWheel's Avatar
It is a 93 del sol si
Old Mar 11, 2014 | 11:04 AM
You wouldn't want to run the stock computer. That is a non VTEC head and your computer is setup for VTEC. It would technically run but would throw codes and not run right. I would find a 92-95 non-VTEC ECU.
Old Mar 11, 2014 | 11:47 AM
BudWheel's Avatar
I have a p06 which is for a 92-95 civic dx installed.
matt2775
11
Jan 2, 2014 09:08 PM
custom rides401
Oct 26, 2010 11:02 AM
2Fast4Everyone
10
Aug 6, 2007 09:50 AM
97civicsedan
May 10, 2005 08:33 AM
