Suspension & Brakes Theory, alignment, spring rates....
Apexi n1 2000spec instructions
Old Mar 11, 2014 | 09:14 AM
bspeed's Avatar
Default Apexi n1 2000spec instructions
Bought a set of used Apexi n1 Pro 2000 spec coilovers used. The guy didnt have the instructions anymore. Katman sent me a link for instructions on FFsquad but they are all in Kanji, Hiragana and Katakana of which I understand zero.
Apexi USA was of little help.
Does anyone have a copy of the English or Engrish instructions for this suspension. I know all the N1's are essentially the same through the different versions. Thank you.
Old Mar 11, 2014 | 02:45 PM
redlinetuning's Avatar
Default Re: Apexi n1 2000spec instructions
Post up a picture of what the coil overs look like. Are they disassembled?
Old Mar 11, 2014 | 05:36 PM
bspeed's Avatar
Here is a picture of the label.
Yes they are assembled, pillowball top hats on etc. I know how to assemble a coil over, what I am looking for are adjustment specs i.e. preload, damping, lower body height….etc.
Old Mar 11, 2014 | 10:06 PM
I see. Definitely technical spec sheet would help. I'll see if I can find something in the morning. It's 1:00am my time.
Old Mar 12, 2014 | 07:59 AM
bspeed's Avatar
Thanks man. I can pm you my email addy if you have them in pdf.
Old Mar 12, 2014 | 07:09 PM
I couldn't really find anything on these either, but I did find this.
https://honda-tech.com/forums/acura-integra-type-r-8/apexi-n1-99-spec-coilovers-how-adjust-dampening-1013460/
Hope it helps.
Old Mar 12, 2014 | 07:46 PM
bspeed's Avatar
Yeah, I have done about every variation of a search boolean on every search engine and found that thread every time.
Old Mar 12, 2014 | 09:16 PM
From what I read, most coilover bodies like this, have 2mm per turn. I know that doesn't help much but at this point, I think it's a trial and error.
Old Mar 12, 2014 | 10:29 PM
bspeed's Avatar
Thanks man, appreciate the help.
Andre
Suspension & Brakes
Jun 27, 2006 11:58 AM
DMF
Dec 15, 2003 06:23 PM
d0nkeyxPunch
Mar 11, 2003 10:24 AM
scottg
Jan 22, 2003 08:23 PM
supergreenNA1
Apr 11, 2002 03:07 PM
