FS IL: '92 Civic VX Hatchback Very Clean
For Sale is my 1992 Honda Civic Vx, Built B18B swap. This car was tuned and partially built (all headwork) at King Motorsports. It made 193 whp/137 whtq on their dyno. All bottom end engine work was done at C&S Performance in Butler, WI. Block has ARP Head studs and ARP Rod bolts. Pistons are 81.25mm JDM P30's. Rods are stock, but are shot-peened for maximum reliability. I do have a build sheet with all bearing clearances, piston-to-wall clearance, main bore measurements, rod journal measurements, main journal measurements, and specific bearings used to achieve those clearances. Bottom end was assembled with appropriate OEM Honda crank and rod bearings. Other parts include Crower 62404 cams, PLM header, Apexi Noir catback exhaust, Skunk2 Pro2 intake manifold, Professional Products throttle body, and RC 370cc injectors, walbro fuel pump. The transmission is also fully rebuilt. B16 Hydro trans with a Quaife LSD, LS 5th gear for maximum cruising MPG, all new Carbon Synchro Set from Synchrotech, and new 3-4 sleeve. Clutch is an Exedy Stage 1 and the Flywheel is ACT Streetlite. B&M short shifter, Hasport shift linkage. The drivetrain only has around 7,000 miles.
I have every receipt for everything done to the car.
Suspension mods:
New Struts with Tein H Tech springs, ASR Rear subframe brace with a 22mm rear bar. Also, the car has new wheel bearings at all corners, new tie rods, new ball joints, Integra GSR front and rear brakes, stainless braided and coated brake lines.
Interior:
2000 Integra LS seats, Innovate wideband, Sunpro electric Oil pressure and oil temperature gauges.
The exterior is in good shape. Carbon fiber duckbill spoiler, Morimoto Projector Retrofit with 5k HID's.
I am asking $5400 My name is Levi and my number is 618-513-4307 I work straight midnights so you can text me anytime.
Suspension mods:
Interior:
Driver rear quarter has a small rust spot but its just under the paint. Its not into the metal. Other than that there is no other rust on the car.
boostedwagon
Aug 13, 2013 02:25 PM
boostedwagon
13
Sep 20, 2009 02:21 PM
Grand
Apr 18, 2005 08:00 PM
