Head Light PROBLEMO - 93 civic - dim bulb
Old Mar 9, 2014 | 08:24 PM
chris the man's Avatar
Icon2 Head Light PROBLEMO - 93 civic - dim bulb
Hey guys, i just purchased this car
1993 Honda Civic
b15 non vtec
For some reason the cars PASSENGER side headlight is dim, even switching to brights it is still dim.
1.) i have checked all fuses- all are good
2.) i have checked 2 bulbs- both were good (tested on driver side)
3.) i have checked most grounds- this is where i think the problem may be. May i get some help as to where the headlight ground may be? Does anyone have a physical picture?
Thanks so much. The halogen bulbs are currently on the car, NO HIDs installed currently
I promise i did as much research as i possibly could before posting. Thanks guys!
Pictures for reference
Do you guys think i should just say F it and get this harness?
http://www.ebay.com/itm/330997592807?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Mar 9, 2014 | 08:31 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Head Light PROBLEMO
I guess you implied you put a known bright bulb (tested on drivers side) into the passenger side and it's still dim?
It looks like the socket is taped up.... I would suspect the issue lies in there.
I know my passenger side had an issue and the socket has gotten brittle, it now has to sit just right on the posts or I don't have a headlight on that side.
I'm just going to cut a used socket from the junkyard and do a solder job on mine to renew the socket.
Maybe that will work for you instead of going the full harness route. Your call though.
Old Mar 9, 2014 | 08:44 PM
I know my passenger side had an issue and the socket has gotten brittle, it now has to side just right on the posts or I don't have a headlight on that side.
Thanks a ton for the reply man, any help is greatly appreciated here. And yes sorry to make that clear you are correct, i checked the bulbs i was trying to use and they are 100% working. Ill start there, it does look like the lines are corroded!
Old Mar 10, 2014 | 06:20 AM
Former User's Avatar
Default Re: Head Light PROBLEMO - 93 civic - dim bulb
Dust off your multimeter and test the bulb socket power and ground terminals for battery voltage and continuity to body ground, respectively.
Old Mar 18, 2014 | 06:02 PM
The right bulb had horribly weak signal. I spent about 2 hours tracing it and checking wires. Lets face it, the car is a 93 and just about everything is corroded...
I ended up buying that new headlight kit and BAM!!!!!! everything works perfect!
Old Mar 18, 2014 | 06:05 PM
B_Swapped93's Avatar
HIDs the light dispersion is horrid on them and they blind on coming traffic, why not just get some good regular bulbs ?
Old Mar 18, 2014 | 06:13 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Something about the passenger side. This makes 3 cars in the 5th gen. Both my 95 and 93 Hatchabck have issues with the passenger side socket. And OP's car is the passenger side. Go figure.
Sol2Take
Lighting
10
Mar 20, 2012 06:10 PM
Don Jefe
Aug 17, 2004 04:34 PM
koshie
Sep 20, 2002 12:56 PM
swtcivic93
Jun 18, 2001 07:41 AM
