civic rear disk brake help
Old Mar 9, 2014 | 03:18 PM
swizz977's Avatar
Default civic rear disk brake help
ok so i have a 92 si oem rear disk brakes i replaced the calipers a few years ago but when i turn the rotor its like the pads are so close to the rotor that it makes noise
also im trying to put the pads back on amd the caliper back on the rotor and the pads are so close together it wont even slide on the rotor am i doing something wrong? the pins are sliding fine
Old Mar 9, 2014 | 03:30 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: civic rear disk brake help
I'm guessing this is your first time replacing brakes?
Remove the cap from the brake fluid reservoir. Use a large C clamp to compress the brake caliper cylinder. Insert pads into the caliper. Remove the slider pins, re-lube, and re-install. Install the now loaded caliper over the disc, bolt it down to the slider. Reinstall the wheel, take the car off jack stands. Accelerate to 15 MPH, then slam on the brakes (without locking them up) three times. Done.
Old Mar 9, 2014 | 03:48 PM
cetcivic's Avatar
no one wants to hear the truth
Great write-up
should be stickied
KISS(keep it simple stupid)
brake pad install
Old Mar 9, 2014 | 04:21 PM
nub's Avatar
nub
The rears don't compress like the fronts, they're threaded. The face of the piston has cross embossed into it. You have to turn the piston clockwise to retract it. You use one of these on a 3/8" ratchet, should be around $10 at most parts stores.
Old Mar 9, 2014 | 05:29 PM
cetcivic's Avatar
That thing is a pain in the *** to use
Makes compressing the piston so tedious since it keeps slipping off of one side as you turn the wrench
Old Mar 9, 2014 | 05:44 PM
NotARaCist's Avatar
Uh, yeah, **** those things. I always just compress them with a clamp, never had any problems.
Old Mar 9, 2014 | 05:45 PM
swizz977's Avatar
ok so moving the slider pins back and forth is not compressing and decompressing the piston?
Old Mar 9, 2014 | 05:47 PM
NotARaCist's Avatar
No, not at all. The sliders are part of the bracket - the piston is part of the caliper.
Old Mar 9, 2014 | 06:22 PM
swizz977's Avatar
oh wow and i thought i knew how to do brakes lol well the front i didnt have to do that
Old Mar 10, 2014 | 02:43 PM
swizz977's Avatar
ok so i bought that cube tool and compressed the piston in greased everything (btw the caliper bracket, is that supposed to be able to slide completely off the slider pins?) but now check out this video i can't even turn my hub i dont know whats wrong https://www.facebook.com/photo.php?v...49458765178882
Old Mar 10, 2014 | 02:56 PM
ctrhatch0920's Avatar
bump
Old Mar 10, 2014 | 02:59 PM
swizz977's Avatar
thanks man I'm pretty sure i put the pads on right i dont know this can't be right
Old Mar 10, 2014 | 03:25 PM
swizz977's Avatar
could it be because i havnt driven it yet? i pressed the pedal a bunch of times.. the slider pins are moving good the push in and feel like they want to push out.. the thing that spins im not sure if thats moving at all i mean i used the tool and compressed it in but idk
Old Mar 10, 2014 | 04:03 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Also, at some point, put cap back on brake fluid reservoir.
Actually, I thought you shouldn't expose the brake fluid to air unnecessarily, as it's hygroscopic and can absorb moisture from the air. But, how long is "too long"?
Old Mar 10, 2014 | 04:09 PM
swizz977's Avatar
also check this out https://www.facebook.com/photo.php?v...75428022529767
Old Mar 10, 2014 | 05:41 PM
swizz977's Avatar
Old Mar 10, 2014 | 08:54 PM
NotARaCist's Avatar
The cap isn't "perfectly airtight" anyway, so it's constantly exposed to the air. The time it takes to properly do a brake job isn't going to do any real harm to the fluid.
ksweetland
Suspension & Brakes
12
May 18, 2012 03:19 AM
jdmsir4dr
Suspension & Brakes
Mar 7, 2010 01:23 PM
KyleVA
Nov 24, 2009 09:39 AM
tjluvsahonda
Oct 4, 2007 08:09 AM
JDM TypeR 307
Feb 27, 2004 06:07 PM
