P0420 2002 Accord VP Automatic California
I have a P0420 code. Checked cruise and deceleration O2 sensor values. At cruise secondary stays 0.5-0.8V and deceleration both drop to 0V. Checked upstream and downstream temp of cat converter: ~360 upstream and ~440 deg F downstream. Reset the code, it came back. Please help.
Cruide data below:
Live Data
Number of DTCs stored in this ECU 1
Fuel system 1 statusCL
Fuel System 2 status--
Calculated LOAD Value(%)40.0
Engine Coolant Temperature(¡£C)86
Short Term Fuel Trim -Bank 1(%)0.0
Long Term Fuel Trim - Bank 1(%)0.0
Intake Manifold Absolute Pressure(kPa)40.0
Engine RPM(rpm) 2428
Vehicle Speed Sensor(km/h)101
Ignition Timing Advanece for #1 Cylinder(¡£)39.0
Intake Air Temperature(¡£C)43
Absolute Throttle Position(%)17.3
Location of Oxygen SensorsB1S12--B2S----
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.135
Short Term Fuel Trim Bank 1-Sensor 1(%)3.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.660
Short Term Fuel Trim Bank 1-Sensor 2(%)0.0
OBD requirements to which vehicle is designedOBDII
Calculated LOAD Value(%)40.4
Short Term Fuel Trim -Bank 1(%)-1.6
Engine RPM(rpm) 2427
Vehicle Speed Sensor(km/h)100
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.660
Short Term Fuel Trim Bank 1-Sensor 1(%)0.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.605
Short Term Fuel Trim Bank 1-Sensor 2(%)2.3
Short Term Fuel Trim -Bank 1(%)0.8
Engine RPM(rpm) 2423
Ignition Timing Advanece for #1 Cylinder(¡£)38.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.680
Short Term Fuel Trim Bank 1-Sensor 1(%)-0.8
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.445
Short Term Fuel Trim Bank 1-Sensor 2(%)3.1
Engine RPM(rpm) 2412
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.760
Short Term Fuel Trim Bank 1-Sensor 1(%)0.8
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.585
Short Term Fuel Trim Bank 1-Sensor 2(%)3.9
Intake Manifold Absolute Pressure(kPa)42.0
Engine RPM(rpm) 2404
Vehicle Speed Sensor(km/h)99
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.270
Short Term Fuel Trim Bank 1-Sensor 1(%)2.3
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.525
Short Term Fuel Trim Bank 1-Sensor 2(%)4.7
Calculated LOAD Value(%)41.2
Short Term Fuel Trim -Bank 1(%)3.1
Intake Manifold Absolute Pressure(kPa)41.0
Engine RPM(rpm) 2395
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.095
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.640
Short Term Fuel Trim Bank 1-Sensor 2(%)0.8
Calculated LOAD Value(%)42.0
Short Term Fuel Trim -Bank 1(%)-0.8
Engine RPM(rpm) 2382
Vehicle Speed Sensor(km/h)98
Ignition Timing Advanece for #1 Cylinder(¡£)38.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.740
Engine Coolant Temperature(¡£C)87
Engine RPM(rpm) 2366
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.230
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.680
Engine RPM(rpm) 2360
Vehicle Speed Sensor(km/h)97
Engine RPM(rpm) 2352
Absolute Throttle Position(%)17.6
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.720
Intake Manifold Absolute Pressure(kPa)43.0
Engine RPM(rpm) 2343
Engine RPM(rpm) 2336
Vehicle Speed Sensor(km/h)96
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.175
Short Term Fuel Trim Bank 1-Sensor 1(%)1.6
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.545
Calculated LOAD Value(%)43.5
Short Term Fuel Trim -Bank 1(%)2.3
Engine RPM(rpm) 2324
Ignition Timing Advanece for #1 Cylinder(¡£)37.5
Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.565
Intake Manifold Absolute Pressure(kPa)44.0
Engine RPM(rpm) 2322
Calculated LOAD Value(%)43.9
Intake Manifold Absolute Pressure(kPa)45.0
Engine RPM(rpm) 2321
Ignition Timing Advanece for #1 Cylinder(¡£)37.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.700
Short Term Fuel Trim Bank 1-Sensor 2(%)-1.6
Calculated LOAD Value(%)44.7
Short Term Fuel Trim -Bank 1(%)3.9
Intake Manifold Absolute Pressure(kPa)46.0
Engine RPM(rpm) 2315
Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1
Calculated LOAD Value(%)14.5
Intake Manifold Absolute Pressure(kPa)12.0
Engine RPM(rpm) 2266
Vehicle Speed Sensor(km/h)93
Ignition Timing Advanece for #1 Cylinder(¡£)36.5
Absolute Throttle Position(%)9.4
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.000
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.000
Fuel system 1 statusOL-Drive
Calculated LOAD Value(%)13.7
Intake Manifold Absolute Pressure(kPa)14.0
Engine RPM(rpm) 2170
Vehicle Speed Sensor(km/h)89
Intake Manifold Absolute Pressure(kPa)15.0
Engine RPM(rpm) 2089
Vehicle Speed Sensor(km/h)86
Absolute Throttle Position(%)13.3
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.800
Short Term Fuel Trim Bank 1-Sensor 1(%)3.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.035
Calculated LOAD Value(%)52.5
Short Term Fuel Trim -Bank 1(%)5.5
Intake Manifold Absolute Pressure(kPa)65.0
Engine RPM(rpm) 2075
Ignition Timing Advanece for #1 Cylinder(¡£)28.5
Absolute Throttle Position(%)21.2
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.605
Short Term Fuel Trim Bank 1-Sensor 1(%)9.4
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.270
Short Term Fuel Trim Bank 1-Sensor 2(%)7.0
Calculated LOAD Value(%)63.9
Short Term Fuel Trim -Bank 1(%)8.6
Engine RPM(rpm) 2131
Vehicle Speed Sensor(km/h)88
Absolute Throttle Position(%)21.6
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.310
Short Term Fuel Trim Bank 1-Sensor 1(%)8.6
Short Term Fuel Trim Bank 1-Sensor 2(%)6.3
Calculated LOAD Value(%)67.5
Short Term Fuel Trim -Bank 1(%)7.0
Intake Manifold Absolute Pressure(kPa)68.0
Engine RPM(rpm) 2186
Vehicle Speed Sensor(km/h)91
Intake Air Temperature(¡£C)42
Absolute Throttle Position(%)22.0
Short Term Fuel Trim Bank 1-Sensor 2(%)5.5
Short Term Fuel Trim -Bank 1(%)4.7
Intake Manifold Absolute Pressure(kPa)58.0
Engine RPM(rpm) 2220
Vehicle Speed Sensor(km/h)92
Ignition Timing Advanece for #1 Cylinder(¡£)31.0
Absolute Throttle Position(%)20.8
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.640
Short Term Fuel Trim Bank 1-Sensor 1(%)7.8
Calculated LOAD Value(%)47.1
Engine RPM(rpm) 2245
Ignition Timing Advanece for #1 Cylinder(¡£)36.0
Absolute Throttle Position(%)18.4
Short Term Fuel Trim Bank 1-Sensor 1(%)7.0
Short Term Fuel Trim -Bank 1(%)6.3
Intake Manifold Absolute Pressure(kPa)48.0
Engine RPM(rpm) 2239
Ignition Timing Advanece for #1 Cylinder(¡£)35.5
Intake Air Temperature(¡£C)41
Absolute Throttle Position(%)19.2
Short Term Fuel Trim Bank 1-Sensor 1(%)10.9
Calculated LOAD Value(%)54.1
Short Term Fuel Trim -Bank 1(%)9.4
Intake Manifold Absolute Pressure(kPa)64.0
Engine RPM(rpm) 2238
Ignition Timing Advanece for #1 Cylinder(¡£)30.0
Intake Air Temperature(¡£C)40
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.115
Short Term Fuel Trim Bank 1-Sensor 1(%)5.5
Engine RPM(rpm) 2247
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.195
Calculated LOAD Value(%)65.9
Intake Manifold Absolute Pressure(kPa)66.0
Engine RPM(rpm) 2248
Ignition Timing Advanece for #1 Cylinder(¡£)29.0
Intake Air Temperature(¡£C)39
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.700
Calculated LOAD Value(%)67.8
Short Term Fuel Trim -Bank 1(%)1.6
Intake Manifold Absolute Pressure(kPa)78.0
Engine RPM(rpm) 2230
Ignition Timing Advanece for #1 Cylinder(¡£)20.5
Absolute Throttle Position(%)26.7
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.505
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.740
Calculated LOAD Value(%)80.0
Short Term Fuel Trim -Bank 1(%)7.8
Intake Manifold Absolute Pressure(kPa)82.0
Engine RPM(rpm) 2250
Ignition Timing Advanece for #1 Cylinder(¡£)21.5
Absolute Throttle Position(%)26.3
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.250
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.720
Calculated LOAD Value(%)78.4
Intake Manifold Absolute Pressure(kPa)72.0
Engine RPM(rpm) 2263
Ignition Timing Advanece for #1 Cylinder(¡£)29.5
Intake Air Temperature(¡£C)38
Absolute Throttle Position(%)19.6
Engine RPM(rpm) 2221
Intake Air Temperature(¡£C)37
Calculated LOAD Value(%)49.8
Intake Manifold Absolute Pressure(kPa)52.0
Engine RPM(rpm) 2191
Vehicle Speed Sensor(km/h)90
Ignition Timing Advanece for #1 Cylinder(¡£)33.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.425
Calculated LOAD Value(%)66.7
Intake Manifold Absolute Pressure(kPa)70.0
Engine RPM(rpm) 2208
Absolute Throttle Position(%)18.8
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.055
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.155
Short Term Fuel Trim Bank 1-Sensor 2(%)7.8
Calculated LOAD Value(%)50.6
Engine Coolant Temperature(¡£C)88
Intake Manifold Absolute Pressure(kPa)51.0
Engine RPM(rpm) 2222
Ignition Timing Advanece for #1 Cylinder(¡£)34.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.780
Calculated LOAD Value(%)51.8
Engine RPM(rpm) 2243
Ignition Timing Advanece for #1 Cylinder(¡£)35.0
Short Term Fuel Trim Bank 1-Sensor 1(%)4.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.625
Calculated LOAD Value(%)49.0
Engine RPM(rpm) 2272
Vehicle Speed Sensor(km/h)94
Short Term Fuel Trim Bank 1-Sensor 2(%)-3.1
Calculated LOAD Value(%)21.6
Short Term Fuel Trim -Bank 1(%)-6.3
Intake Manifold Absolute Pressure(kPa)22.0
Engine RPM(rpm) 2253
Short Term Fuel Trim Bank 1-Sensor 1(%)-7.0
Short Term Fuel Trim Bank 1-Sensor 2(%)-8.6
Short Term Fuel Trim -Bank 1(%)-7.0
Engine RPM(rpm) 2241
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.230
Engine RPM(rpm) 2214
Absolute Throttle Position(%)9.8
Engine RPM(rpm) 2192
Engine RPM(rpm) 2177
Engine RPM(rpm) 2159
Engine RPM(rpm) 2137
Absolute Throttle Position(%)11.0
Short Term Fuel Trim Bank 1-Sensor 1(%)6.3
Calculated LOAD Value(%)32.9
Engine Coolant Temperature(¡£C)84
Intake Manifold Absolute Pressure(kPa)35.0
Engine RPM(rpm) 2158
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.135
Calculated LOAD Value(%)58.0
Intake Manifold Absolute Pressure(kPa)59.0
Ignition Timing Advanece for #1 Cylinder(¡£)32.5
Absolute Throttle Position(%)20.4
Short Term Fuel Trim Bank 1-Sensor 2(%)1.6
Calculated LOAD Value(%)60.4
Intake Manifold Absolute Pressure(kPa)63.0
Engine RPM(rpm) 2269
Calculated LOAD Value(%)62.4
Engine RPM(rpm) 2316
Calculated LOAD Value(%)64.3
Engine RPM(rpm) 2367
Ignition Timing Advanece for #1 Cylinder(¡£)30.5
Calculated LOAD Value(%)46.3
Intake Manifold Absolute Pressure(kPa)47.0
Engine RPM(rpm) 2393
Calculated LOAD Value(%)48.2
Intake Manifold Absolute Pressure(kPa)50.0
Engine RPM(rpm) 2391
Intake Manifold Absolute Pressure(kPa)53.0
Calculated LOAD Value(%)56.1
Intake Manifold Absolute Pressure(kPa)57.0
Engine RPM(rpm) 2435
Long Term Fuel Trim - Bank 1(%)0.8
Engine RPM(rpm) 2458
Vehicle Speed Sensor(km/h)102
Calculated LOAD Value(%)59.6
Engine RPM(rpm) 2492
Vehicle Speed Sensor(km/h)103
Ignition Timing Advanece for #1 Cylinder(¡£)32.0
Absolute Throttle Position(%)23.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.485
Calculated LOAD Value(%)72.2
Intake Manifold Absolute Pressure(kPa)75.0
Engine RPM(rpm) 2559
Vehicle Speed Sensor(km/h)106
Ignition Timing Advanece for #1 Cylinder(¡£)27.0
Absolute Throttle Position(%)25.1
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.210
Calculated LOAD Value(%)74.5
Engine RPM(rpm) 2609
Vehicle Speed Sensor(km/h)108
Ignition Timing Advanece for #1 Cylinder(¡£)41.0
Absolute Throttle Position(%)15.7
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.290
Short Term Fuel Trim Bank 1-Sensor 1(%)-8.6
Short Term Fuel Trim Bank 1-Sensor 2(%)-6.3
Calculated LOAD Value(%)30.6
Short Term Fuel Trim -Bank 1(%)-7.8
Intake Manifold Absolute Pressure(kPa)34.0
Engine RPM(rpm) 2571
Short Term Fuel Trim Bank 1-Sensor 1(%)-4.7
Calculated LOAD Value(%)39.2
Intake Manifold Absolute Pressure(kPa)39.0
Engine RPM(rpm) 2555
Vehicle Speed Sensor(km/h)105
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.035
Calculated LOAD Value(%)11.8
Intake Manifold Absolute Pressure(kPa)13.0
Engine RPM(rpm) 2461
Ignition Timing Advanece for #1 Cylinder(¡£)39.5
Calculated LOAD Value(%)33.7
Intake Manifold Absolute Pressure(kPa)55.0
Engine RPM(rpm) 2400
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.210
Calculated LOAD Value(%)80.8
Intake Manifold Absolute Pressure(kPa)83.0
Engine RPM(rpm) 2429
Ignition Timing Advanece for #1 Cylinder(¡£)21.0
Absolute Throttle Position(%)27.8
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.585
Calculated LOAD Value(%)71.0
Engine RPM(rpm) 2455
Absolute Throttle Position(%)23.1
Engine RPM(rpm) 2444
Live Data
Cruide data below:
Live Data
Live Data
Idle and normal operation data:
Calculated LOAD Value(%)29.4
Engine Coolant Temperature(¡£C)95
Short Term Fuel Trim -Bank 1(%)-3.1
Long Term Fuel Trim - Bank 1(%)-3.1
Intake Manifold Absolute Pressure(kPa)30.0
Engine RPM(rpm) 700
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(¡£)12.0
Intake Air Temperature(¡£C)69
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.835
Short Term Fuel Trim Bank 1-Sensor 1(%)-3.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.820
Short Term Fuel Trim Bank 1-Sensor 2(%)-4.7
Short Term Fuel Trim -Bank 1(%)-5.5
Engine RPM(rpm) 695
Short Term Fuel Trim Bank 1-Sensor 1(%)-6.3
Short Term Fuel Trim Bank 1-Sensor 2(%)-7.0
Intake Manifold Absolute Pressure(kPa)29.0
Engine RPM(rpm) 703
Ignition Timing Advanece for #1 Cylinder(¡£)12.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.855
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.780
Short Term Fuel Trim -Bank 1(%)-10.2
Engine RPM(rpm) 700
Short Term Fuel Trim Bank 1-Sensor 1(%)-10.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.800
Short Term Fuel Trim Bank 1-Sensor 2(%)-10.9
Calculated LOAD Value(%)28.6
Short Term Fuel Trim -Bank 1(%)-11.7
Engine RPM(rpm) 690
Short Term Fuel Trim Bank 1-Sensor 1(%)-14.8
Short Term Fuel Trim Bank 1-Sensor 2(%)-14.8
Calculated LOAD Value(%)30.2
Short Term Fuel Trim -Bank 1(%)-14.1
Long Term Fuel Trim - Bank 1(%)-2.3
Engine RPM(rpm) 691
Short Term Fuel Trim Bank 1-Sensor 1(%)-14.1
Short Term Fuel Trim Bank 1-Sensor 2(%)-14.1
Engine Coolant Temperature(¡£C)96
Short Term Fuel Trim -Bank 1(%)-13.3
Engine RPM(rpm) 704
Short Term Fuel Trim Bank 1-Sensor 1(%)-11.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.175
Short Term Fuel Trim Bank 1-Sensor 2(%)-12.5
Short Term Fuel Trim -Bank 1(%)-12.5
Engine RPM(rpm) 706
Ignition Timing Advanece for #1 Cylinder(¡£)11.5
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.115
Short Term Fuel Trim Bank 1-Sensor 2(%)-11.7
Short Term Fuel Trim -Bank 1(%)-10.9
Engine RPM(rpm) 701
Short Term Fuel Trim -Bank 1(%)-9.4
Engine RPM(rpm) 710
Short Term Fuel Trim Bank 1-Sensor 1(%)-9.4
Short Term Fuel Trim Bank 1-Sensor 2(%)-9.4
Engine RPM(rpm) 732
Ignition Timing Advanece for #1 Cylinder(¡£)16.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.075
Calculated LOAD Value(%)34.1
Engine RPM(rpm) 663
Short Term Fuel Trim Bank 1-Sensor 1(%)-10.2
Calculated LOAD Value(%)37.3
Intake Manifold Absolute Pressure(kPa)37.0
Engine RPM(rpm) 731
Ignition Timing Advanece for #1 Cylinder(¡£)15.5
Short Term Fuel Trim Bank 1-Sensor 1(%)-12.5
Short Term Fuel Trim Bank 1-Sensor 2(%)-13.3
Calculated LOAD Value(%)35.7
Engine RPM(rpm) 736
Engine Coolant Temperature(¡£C)97
Engine RPM(rpm) 745
Ignition Timing Advanece for #1 Cylinder(¡£)16.0
Calculated LOAD Value(%)36.5
Engine RPM(rpm) 771
Ignition Timing Advanece for #1 Cylinder(¡£)14.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.505
Engine RPM(rpm) 663
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.875
Intake Manifold Absolute Pressure(kPa)36.0
Engine RPM(rpm) 660
Short Term Fuel Trim Bank 1-Sensor 1(%)-15.6
Short Term Fuel Trim Bank 1-Sensor 2(%)-15.6
Engine RPM(rpm) 731
Vehicle Speed Sensor(km/h)2
Short Term Fuel Trim Bank 1-Sensor 1(%)-13.3
Engine Coolant Temperature(¡£C)93
Engine RPM(rpm) 758
Ignition Timing Advanece for #1 Cylinder(¡£)15.0
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.095
Calculated LOAD Value(%)34.9
Engine Coolant Temperature(¡£C)92
Intake Manifold Absolute Pressure(kPa)32.0
Engine RPM(rpm) 717
Vehicle Speed Sensor(km/h)3
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.055
Engine RPM(rpm) 723
Vehicle Speed Sensor(km/h)4
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.075
Engine RPM(rpm) 742
Intake Manifold Absolute Pressure(kPa)33.0
Engine RPM(rpm) 747
Ignition Timing Advanece for #1 Cylinder(¡£)13.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.820
Engine RPM(rpm) 672
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.410
Short Term Fuel Trim Bank 1-Sensor 2(%)-0.8
Engine RPM(rpm) 666
Vehicle Speed Sensor(km/h)5
Engine RPM(rpm) 935
Ignition Timing Advanece for #1 Cylinder(¡£)22.0
Calculated LOAD Value(%)25.9
Intake Manifold Absolute Pressure(kPa)26.0
Engine RPM(rpm) 810
Ignition Timing Advanece for #1 Cylinder(¡£)7.5
Calculated LOAD Value(%)26.7
Intake Manifold Absolute Pressure(kPa)27.0
Engine RPM(rpm) 773
Vehicle Speed Sensor(km/h)7
Intake Manifold Absolute Pressure(kPa)38.0
Engine RPM(rpm) 1055
Ignition Timing Advanece for #1 Cylinder(¡£)27.5
Absolute Throttle Position(%)13.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.195
Calculated LOAD Value(%)23.5
Engine RPM(rpm) 1234
Vehicle Speed Sensor(km/h)14
Absolute Throttle Position(%)11.4
Engine RPM(rpm) 1626
Vehicle Speed Sensor(km/h)15
Ignition Timing Advanece for #1 Cylinder(¡£)33.0
Calculated LOAD Value(%)24.3
Short Term Fuel Trim -Bank 1(%)-3.9
Intake Manifold Absolute Pressure(kPa)25.0
Engine RPM(rpm) 918
Vehicle Speed Sensor(km/h)18
Ignition Timing Advanece for #1 Cylinder(¡£)10.5
Calculated LOAD Value(%)27.1
Intake Manifold Absolute Pressure(kPa)28.0
Engine RPM(rpm) 782
Vehicle Speed Sensor(km/h)12
Ignition Timing Advanece for #1 Cylinder(¡£)14.5
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.425
Calculated LOAD Value(%)32.2
Engine RPM(rpm) 647
Engine RPM(rpm) 729
Calculated LOAD Value(%)38.4
Intake Manifold Absolute Pressure(kPa)31.0
Engine RPM(rpm) 861
Ignition Timing Advanece for #1 Cylinder(¡£)22.5
Absolute Throttle Position(%)12.2
Calculated LOAD Value(%)31.4
Engine RPM(rpm) 905
Ignition Timing Advanece for #1 Cylinder(¡£)13.5
Engine RPM(rpm) 793
Ignition Timing Advanece for #1 Cylinder(¡£)9.5
Engine RPM(rpm) 1241
Absolute Throttle Position(%)12.5
Short Term Fuel Trim Bank 1-Sensor 2(%)9.4
Engine RPM(rpm) 1614
Vehicle Speed Sensor(km/h)16
Short Term Fuel Trim Bank 1-Sensor 1(%)-2.3
Engine RPM(rpm) 906
Vehicle Speed Sensor(km/h)21
Ignition Timing Advanece for #1 Cylinder(¡£)7.0
Calculated LOAD Value(%)23.1
Intake Manifold Absolute Pressure(kPa)24.0
Engine RPM(rpm) 946
Vehicle Speed Sensor(km/h)23
Engine RPM(rpm) 867
Engine RPM(rpm) 693
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.015
Engine RPM(rpm) 1001
Intake Manifold Absolute Pressure(kPa)21.0
Engine RPM(rpm) 1096
Engine RPM(rpm) 803
Absolute Throttle Position(%)12.9
Live Data
Calculated LOAD Value(%)53.3
Engine RPM(rpm) 2207
Vehicle Speed Sensor(km/h)24
Calculated LOAD Value(%)78.0
Intake Manifold Absolute Pressure(kPa)71.0
Engine RPM(rpm) 2380
Vehicle Speed Sensor(km/h)38
Ignition Timing Advanece for #1 Cylinder(¡£)26.5
Intake Air Temperature(¡£C)68
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.465
Vehicle Speed Sensor(km/h)46
Ignition Timing Advanece for #1 Cylinder(¡£)23.0
Absolute Throttle Position(%)23.5
Engine RPM(rpm) 2150
Vehicle Speed Sensor(km/h)51
Intake Air Temperature(¡£C)67
Engine RPM(rpm) 1663
Vehicle Speed Sensor(km/h)54
Absolute Throttle Position(%)14.5
Engine RPM(rpm) 1358
Absolute Throttle Position(%)14.1
Engine RPM(rpm) 1383
Vehicle Speed Sensor(km/h)53
Engine RPM(rpm) 1291
Vehicle Speed Sensor(km/h)52
Ignition Timing Advanece for #1 Cylinder(¡£)28.0
Intake Air Temperature(¡£C)66
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.625
Short Term Fuel Trim Bank 1-Sensor 1(%)-5.5
Engine RPM(rpm) 1439
Vehicle Speed Sensor(km/h)49
Calculated LOAD Value(%)75.7
Intake Manifold Absolute Pressure(kPa)77.0
Engine RPM(rpm) 1789
Vehicle Speed Sensor(km/h)50
Absolute Throttle Position(%)22.4
Intake Manifold Absolute Pressure(kPa)56.0
Engine RPM(rpm) 1768
Short Term Fuel Trim Bank 1-Sensor 2(%)-3.9
Engine RPM(rpm) 1030
Intake Air Temperature(¡£C)65
Engine Coolant Temperature(¡£C)91
Engine RPM(rpm) 931
Short Term Fuel Trim -Bank 1(%)-2.3
Engine RPM(rpm) 915
Vehicle Speed Sensor(km/h)45
Short Term Fuel Trim Bank 1-Sensor 2(%)-2.3
Engine RPM(rpm) 911
Calculated LOAD Value(%)25.1
Engine RPM(rpm) 861
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.485
Engine RPM(rpm) 850
Vehicle Speed Sensor(km/h)28
Absolute Throttle Position(%)10.6
Calculated LOAD Value(%)70.2
Engine RPM(rpm) 1996
Vehicle Speed Sensor(km/h)26
Ignition Timing Advanece for #1 Cylinder(¡£)23.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.155
Calculated LOAD Value(%)76.5
Intake Manifold Absolute Pressure(kPa)76.0
Engine RPM(rpm) 2340
Vehicle Speed Sensor(km/h)34
Absolute Throttle Position(%)24.7
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.545
Calculated LOAD Value(%)72.9
Engine Coolant Temperature(¡£C)90
Engine RPM(rpm) 2522
Vehicle Speed Sensor(km/h)40
Ignition Timing Advanece for #1 Cylinder(¡£)25.5
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.835
Calculated LOAD Value(%)60.8
Engine RPM(rpm) 1933
Vehicle Speed Sensor(km/h)42
Calculated LOAD Value(%)18.0
Engine RPM(rpm) 1287
Vehicle Speed Sensor(km/h)35
Short Term Fuel Trim Bank 1-Sensor 2(%)-5.5
Short Term Fuel Trim -Bank 1(%)-4.7
Engine RPM(rpm) 1397
Vehicle Speed Sensor(km/h)32
Engine RPM(rpm) 957
Vehicle Speed Sensor(km/h)27
Engine RPM(rpm) 799
Vehicle Speed Sensor(km/h)20
Ignition Timing Advanece for #1 Cylinder(¡£)11.0
Engine RPM(rpm) 687
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.07Short Term Fuel Trim Bank 1-Sensor 2(%)-3.9
Calculated LOAD Value(%)68.6
Engine RPM(rpm) 2071
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.190
Calculated LOAD Value(%)69.4
Engine RPM(rpm) 2283
Ignition Timing Advanece for #1 Cylinder(¡£)17.5
Calculated LOAD Value(%)84.7
Engine RPM(rpm) 2607
Ignition Timing Advanece for #1 Cylinder(¡£)18.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.170
Engine RPM(rpm) 2893
Intake Air Temperature(¡£C)63
Calculated LOAD Value(%)74.9
Engine RPM(rpm) 2326
Engine RPM(rpm) 2376
Engine RPM(rpm) 2485
Engine RPM(rpm) 2520
Ignition Timing Advanece for #1 Cylinder(¡£)26.0
Calculated LOAD Value(%)42.7
Engine RPM(rpm) 2240
Engine RPM(rpm) 2112
Calculated LOAD Value(%)58.8
Engine RPM(rpm) 2156
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.090
Engine RPM(rpm) 2016
Engine RPM(rpm) 1183
Calculated LOAD Value(%)19.6
Engine RPM(rpm) 1197
Vehicle Speed Sensor(km/h)36
Intake Air Temperature(¡£C)60
Short Term Fuel Trim -Bank 1(%)-8.6
Engine RPM(rpm) 798
Engine RPM(rpm) 1171
Ignition Timing Advanece for #1 Cylinder(¡£)19.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.130
Engine RPM(rpm) 1950
Ignition Timing Advanece for #1 Cylinder(¡£)24.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.620
Calculated LOAD Value(%)73.7
Engine RPM(rpm) 2359
Engine RPM(rpm) 2615
Calculated LOAD Value(%)55.3
Engine RPM(rpm) 1897
Engine RPM(rpm) 1596
Engine RPM(rpm) 1265
Calculated LOAD Value(%)17.3
Engine RPM(rpm) 1268
Engine RPM(rpm) 1281
Calculated LOAD Value(%)16.9
Engine RPM(rpm) 1302
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.540
Short Term Fuel Trim Bank 1-Sensor 2(%)-7.8
Engine RPM(rpm) 1320
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.050
Engine RPM(rpm) 1399
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.72Short Term Fuel Trim Bank 1-Sensor 2(%)2.3
Engine RPM(rpm) 1479
Intake Air Temperature(¡£C)62
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.76
Engine RPM(rpm) 1554
Engine RPM(rpm) 1613
Ignition Timing Advanece for #1 Cylinder(¡£)31.5
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.150
Engine RPM(rpm) 1618
Engine RPM(rpm) 686
Engine RPM(rpm) 686
Engine RPM(rpm) 693
Engine RPM(rpm) 691
Engine RPM(rpm) 688
Engine RPM(rpm) 689
Engine RPM(rpm) 696
Calculated LOAD Value(%)27.8
Engine RPM(rpm) 698
Engine RPM(rpm) 696
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.370
Engine RPM(rpm) 697
Engine RPM(rpm) 696
Engine RPM(rpm) 697
Engine RPM(rpm) 703
Engine RPM(rpm) 704
Engine RPM(rpm) 700
Engine RPM(rpm) 695
Engine RPM(rpm) 703
Engine RPM(rpm) 700
Engine RPM(rpm) 690
Engine RPM(rpm) 691
Engine RPM(rpm) 704
Engine RPM(rpm) 706
Engine RPM(rpm) 701
Engine RPM(rpm) 710
Engine RPM(rpm) 732
Engine RPM(rpm) 663
Engine RPM(rpm) 731
Engine RPM(rpm) 736
Engine RPM(rpm) 745
Engine RPM(rpm) 771
Engine RPM(rpm) 663
Engine RPM(rpm) 660
Engine RPM(rpm) 731
Engine RPM(rpm) 758
Engine RPM(rpm) 717
Engine RPM(rpm) 723
Engine RPM(rpm) 742
Engine RPM(rpm) 747
Engine RPM(rpm) 672
Engine RPM(rpm) 666
Engine RPM(rpm) 935
Engine RPM(rpm) 810
Engine RPM(rpm) 773
Engine RPM(rpm) 918
Engine RPM(rpm) 782
Engine RPM(rpm) 647
Engine RPM(rpm) 729
Engine RPM(rpm) 861
Engine RPM(rpm) 905
Engine RPM(rpm) 793
Engine RPM(rpm) 906
Engine RPM(rpm) 946
Engine RPM(rpm) 867
Engine RPM(rpm) 693
Engine RPM(rpm) 803
Engine RPM(rpm) 700
Engine RPM(rpm) 695
Engine RPM(rpm) 703
Engine RPM(rpm) 700
Engine RPM(rpm) 690
Engine RPM(rpm) 691
Engine RPM(rpm) 704
Engine RPM(rpm) 706
Engine RPM(rpm) 701
Engine RPM(rpm) 710
Engine RPM(rpm) 732
Engine RPM(rpm) 663
Engine RPM(rpm) 731
Engine RPM(rpm) 736
Engine RPM(rpm) 745
Engine RPM(rpm) 771
Engine RPM(rpm) 663
Engine RPM(rpm) 660
Engine RPM(rpm) 731
Engine RPM(rpm) 758
Engine RPM(rpm) 717
Engine RPM(rpm) 723
Engine RPM(rpm) 742
Engine RPM(rpm) 747
Engine RPM(rpm) 672
Engine RPM(rpm) 666
Engine RPM(rpm) 935
Engine RPM(rpm) 810
Engine RPM(rpm) 773
Engine RPM(rpm) 918
Engine RPM(rpm) 782
Engine RPM(rpm) 647
Engine RPM(rpm) 729
Engine RPM(rpm) 861
Engine RPM(rpm) 905
Engine RPM(rpm) 793
Engine RPM(rpm) 906
Engine RPM(rpm) 946
Engine RPM(rpm) 867
Engine RPM(rpm) 693
Engine RPM(rpm) 803
Live Data
Engine RPM(rpm) 931
Engine RPM(rpm) 915
Engine RPM(rpm) 911
Engine RPM(rpm) 861
Engine RPM(rpm) 850
Engine RPM(rpm) 957
Engine RPM(rpm) 799
Engine RPM(rpm) 687
Engine RPM(rpm) 798
Engine RPM(rpm) 686
Engine RPM(rpm) 686
Engine RPM(rpm) 693
Engine RPM(rpm) 691
Engine RPM(rpm) 688
Engine RPM(rpm) 689
Engine RPM(rpm) 696
Engine RPM(rpm) 698
Engine RPM(rpm) 696
Engine RPM(rpm) 697
Engine RPM(rpm) 696
Engine RPM(rpm) 697
Engine RPM(rpm) 703
Engine RPM(rpm) 704
Engine RPM(rpm) 700
Engine RPM(rpm) 695
Engine RPM(rpm) 703
Engine RPM(rpm) 700
Engine RPM(rpm) 690
Engine RPM(rpm) 691
Engine RPM(rpm) 704
Engine RPM(rpm) 706
Engine RPM(rpm) 701
Engine RPM(rpm) 710
Engine RPM(rpm) 732
Engine RPM(rpm) 663
Engine RPM(rpm) 731
Engine RPM(rpm) 736
Engine RPM(rpm) 745
Engine RPM(rpm) 771
Engine RPM(rpm) 663
Engine RPM(rpm) 660
Engine RPM(rpm) 731
Engine RPM(rpm) 758
Engine RPM(rpm) 717
Engine RPM(rpm) 723
Engine RPM(rpm) 742
Engine RPM(rpm) 747
Engine RPM(rpm) 672
Engine RPM(rpm) 666
Engine RPM(rpm) 935
Engine RPM(rpm) 810
Engine RPM(rpm) 773
Engine RPM(rpm) 918
Engine RPM(rpm) 782
Engine RPM(rpm) 647
Engine RPM(rpm) 729
Engine RPM(rpm) 861
Engine RPM(rpm) 905
Engine RPM(rpm) 793
Engine RPM(rpm) 906
Engine RPM(rpm) 946
Engine RPM(rpm) 867
Engine RPM(rpm) 693
Engine RPM(rpm) 803
Well that's a **** load of information I probably am not going to look at line by line, and at the moment cannot imagine it as streaming so...
The catalyst itself should be in the 550-750°F range for best working efficiency.
If it is not in this temp range combustion cannot properly take place for catalyzing.
While looking at your screen if the Primary O2 is switching rich/lean flags at a normal pace(voltage wise) then it may be that the catalyst is failing.
Record the data at cruise(a snapshot at about 30mph,not ALL the data) and at Idle and put it up. Dont bother with the temp test,it will tell you nothing. Operating range of the cat is 1200-1500 degrees which you will never achieve at idle. Just post up the data I asked for and I can easily tell you if the cat is good or not.....
30mph data:
Engine RPM(rpm) 1887
Ignition Timing Advanece for #1 Cylinder(¡£)20.0
Intake Air Temperature(¡£C)51
Absolute Throttle Position(%)16.9
Calculated LOAD Value(%)63.1
Intake Manifold Absolute Pressure(kPa)73.0
Engine RPM(rpm) 1912
Vehicle Speed Sensor(km/h)48
Ignition Timing Advanece for #1 Cylinder(¡£)24.5
Intake Manifold Absolute Pressure(kPa)61.0
Engine RPM(rpm) 1783
Calculated LOAD Value(%)54.5
Engine RPM(rpm) 1661
Engine RPM(rpm) 1484
Calculated LOAD Value(%)51.0
Engine RPM(rpm) 1411
Idle Data:
Engine RPM(rpm) 715
Intake Air Temperature(¡£C)50
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.760
Engine RPM(rpm) 721
Short Term Fuel Trim Bank 1-Sensor 1(%)-7.8
Engine RPM(rpm) 741
Engine RPM(rpm) 757
Engine RPM(rpm) 761
Engine RPM(rpm) 763
Engine RPM(rpm) 757
Engine RPM(rpm) 715
Engine RPM(rpm) 721
Engine RPM(rpm) 741
Engine RPM(rpm) 757
Engine RPM(rpm) 761
Engine RPM(rpm) 763
Engine RPM(rpm) 757
Fuel trim and o2 sensor activity show that the vehicle is in proper fuel control and that there are no exhaust leaks. Replace the cat.
RA022626
Jul 15, 2015 06:34 PM
WTB AUTO EK
Jan 6, 2005 08:55 PM
