crankshaft position senser
Code 4 Crank sensor determines timing for fuel injection and ignition of each cylinder and also detects engine rpm.
Disconnect 6P connector on dist. [square] Measure resistance between two bottom wires. R should be 350-550 ohm. If not, dist is bad. If yes, check continuity to body separately each bottom wire. If yes continuity, dist is bad.
edm_ef8
Jun 21, 2009 11:42 AM
darksolguy
Jul 15, 2008 10:59 PM
EKRACER123456
Jan 30, 2005 01:12 PM
nayrone
Nov 1, 2004 12:09 PM
Blaze45
Dec 13, 2003 06:28 PM
