Injectors differences
Old Mar 8, 2014 | 12:29 PM
sirtef9's Avatar
Default Injectors differences
Built ls vtec
what injectors?
Whats the difference on saturated and peak and hold?
I was using 750cc rc's but not sure saturated or peak?
thanks
Old Mar 8, 2014 | 12:33 PM
Fliptard's Avatar
Default Re: Injectors differences
One of them uses a resistor box and the other does not.
Old Mar 8, 2014 | 12:35 PM
sirtef9's Avatar
so 92 gsr, no resistor box. What do I go with?
Old Mar 8, 2014 | 12:41 PM
Fliptard's Avatar
Peak and Hold are the injectors that require a resistor box. They will run without a box, but I think eventually either the injectors or ECU will crap out. You can wire in a resistor box, but that's something I have yet to do or research into.
Old Mar 9, 2014 | 09:00 PM
m4xwellmurd3r's Avatar
I looked this up for a different thread. If you run peak and hold injectors without a resistor box you wilk fry the ecu. The injector drivers will pop
ej1serge
Mar 14, 2012 11:33 PM
boosted96teg
Mar 15, 2008 06:35 AM
deucedeuceEK
Oct 30, 2007 04:35 PM
B18 CYA
Jun 24, 2004 06:44 PM
