Are there any disadvantages to buying a Crx HF vs A crx Si??
Thanks
My big concern is I'm seeing suspension, camber ... , etc., only for the CRX si??? Does the HF have different suspension components that will make it much more difficult to work with a HF rather than working with a si?
plus the front nuckles on the DX and Si are the same
the axles on the Dx and SI are different... they also have diff knuckles.. the Si one its a bit bigger but has same amount of teeth...been there done that with my Si tranny and STD knuckles
you will have to change hubs and axles on the hf
b16 hf here. just swap out the suspension stuff for integra components for bigger breaks. there's nothing better than light weight
if i had it to do over, it would have been an HF for me. swap in the 91 black si dash and cluster, teg brakes all around, and weld in a roll cage. sounds like my 89 SI.
another b16 hf here...i would go with the hf...only thing different you have to change is the knuckles and its well worth it...the hf is much lighter and just as easy to swap as the si...i would deff. go with hf if not that then the si...and the hf should be cheaper too
97SS
Sep 21, 2007 04:03 AM
