crank pulley help???
Old Mar 7, 2014 | 09:52 PM
ghosthatch's Avatar
Default crank pulley help???
am i seeing things or is this crank pulley cut?
not to mention someone welded it to the damn crank
im doing a b20z swap and wanted to swap the crank pulleys from my old ls motor
i dont need p/s or a/c. i've been outta the game for a while now and trying to finish this swap up quickly. which pulleys can i use? obviously i want the smaller shorter pulleys
not to mention that big *** crack over there^^^
Old Mar 8, 2014 | 01:34 AM
holmesnmanny's Avatar
Default Re: crank pulley help???
First things first, replace that key. That thing is in real bad shape. That pulley doesn't look cut but it's seen better days. And just because you have a pulley with more ribs it doesn't mean you gotta use them.
Old Mar 8, 2014 | 03:29 PM
ghosthatch's Avatar
yeah, it looks like they cut off the last set of ribs off of it. if you look closely at the first picture you might be able to tell. i dont plan on using this pulley after all. it's gonna stay RIIIIGHT where it is
DARKTEG_
Aug 13, 2006 03:15 PM
HonCiv
12
Nov 15, 2002 10:01 AM
Biggspeed
Jan 18, 2002 01:00 AM
