Reluctor on the distributor
can a reluctor on the distributor just break and dissapear?....there is none on mine anymore and maybe thats why my car wont start? can anyone give me anymore info on this thing. My lude is just one prob after another for me
I assume you're talking about the trigger wheel. The magnetic trigger is also called a reluctor.
What year is your car? 97+ only has the one tooth CYP sensor in the distributor and it looks pretty empty.
http://www.higginstribe.com/gallery/...e=DSC00053.JPG
Comparied to an OBD1 distributor:
http://www.higginstribe.com/gallery/rebuild/index.php?image
You need to give more information about the problem. Are you getting a CEL? Is it sputtering, or not even catching.
EDIT: Well, the retarded message translator translates some of the characters in the second link to a smiley face, so it doesn't work. It'll take you to the picture index, though and you can find the picture old-dissy1.jpg.
[Modified by DirtyLude, 4:24 PM 10/29/2002]
[Modified by DirtyLude, 4:26 PM 10/29/2002]
ld-dissy1.jpgYou need to give more information about the problem. Are you getting a CEL? Is it sputtering, or not even catching.
What are you talking about? You mean you don't even have the single wheel at all? You should only have the single 1 tooth wheel in your H22a4 distributor. The other 2 magnetic triggers have moved to the crank in the H22a4.
i believe you ahve an OBD-2 distributor........i think they only have 1 reluctor in the distributor........OBD-1 has more because the crank position sensor is in the distributor too. i do have one laying around if you want it. i will let you have it really cheap. let me dig it up and get a pic for you.........if your interested. let me know. thanks
frank
frank
