97 ex wont rev over 1500
I recently bought this car, it ran fine. It happened while I was driving, I just lost all power and ever since then it wont rev past 1500rpm ? Its the 2.2 vtec has cold air and aftermarket exhaust, other than that its all stock
Check for any trouble codes via the two wire blue connector behind/below the glove box.
Might be something in the exhaust has collapsed and blocks flow, muffler, resonator or catalyst.
My 97 was doing this same thing the codes said I needed a new transmission shift solenoid I watched this video did what the guy said and now it revs and drives fine. You might want to try this
http://m.youtube.com/watch?v=qGq8AM_BvH4
Code was 65 (o2 sensor) replaced that and it made it worse, I took the exhaust off from the cat back...still no luck. I also tested what the guy below posted, both working.
Donnie Martell
50
Feb 25, 2016 12:53 PM
ahhshietitztony
May 25, 2009 02:16 PM
