Passing Emissions with 00 Civic/type r 96-97 swap/P28 ECU?
Old Mar 7, 2014 | 03:28 AM
nuffsaidmikey's Avatar
Default Passing Emissions with 00 Civic/type r 96-97 swap/P28 ECU?
Got a type r 96-97 obd2 motor in a EK 2000. im currently running a chipped p28 with step down harness... my original harness is obd2b
For emissions which ecu should i use? The em1 si one? p2t-c12
and is there anything else i would need?
Old Mar 7, 2014 | 04:09 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: Passing Emissions?
run a type R OBD2B ECU, you will have other sensor issues possibly but since you did not tell us what model car we can not help you there. Also what state are you in?
Old Mar 7, 2014 | 04:18 AM
apexi_rsx's Avatar
a b16 ecu would probably be enough to get you through as long as ur still using stock 240cc injectors. the ecu must be a USDM ecu ; JDM ecu's will not work either...
Old Mar 7, 2014 | 04:44 AM
doctorake's Avatar
Community Builder
Not if it is a JDM motor with out the crank sensor, also if he ha a hatch back he will fail for a lack of the FTP sensor.
Old Mar 12, 2014 | 02:08 PM
its a 2000 ek Coupe, Stock 96-97 type r.. with original Ek obd2b harness
Old Mar 12, 2014 | 02:30 PM
I have a p2t-c12 SI ecu... if i bypass the ckf and run my usdm vtec solenoid to the ecu harness. will it work properly?
Old Mar 12, 2014 | 05:20 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Yes. Depending on how your state tests.
Old Mar 12, 2014 | 05:21 PM
B serious's Avatar
Where does one get a OBD2B ITR ECU?
Old Mar 12, 2014 | 05:41 PM
doctorake's Avatar
Community Builder
Used?
Old Mar 12, 2014 | 06:26 PM
B serious's Avatar
Used?
Immobilizer. Only 3 thousand something ITR's produced in the US. Probably only about 2000 or so in 00-01 (OBD2B). The struggle to find one is real. You'd have to find someone selling their key, antenna, and ECU. Finding someone selling a OBD2B ITR ECU is hard enough.
Old Mar 12, 2014 | 06:28 PM
B serious's Avatar
Default Re: Passing Emissions with 00 Civic/type r 96-97 swap/P28 ECU?
On the other hand, a 99-00 Si ECU is cheap and they errwhurr. You could use a 99-00 EX ECU also. Those would be the cheapest ways to pasd emissions.
Even if you could find someone selling a USDM ITR ECU, it'd probably be stolen and it'd probably cost millions anyway. I should have kept mine when I sold my ITR :'(
You would also have to jump the fuel pump wire to run an integra ECU in a civic without any sandwich harness.
Old Mar 12, 2014 | 06:44 PM
tony_2018's Avatar
Fish Twig
Uuuh.......no....
OP find an obd2a p73 ecu.
Old Mar 12, 2014 | 08:22 PM
B serious's Avatar
Originally Posted by tony_2018
Uuuh.......no....
There were 300 something USDM ITR's made in 97. Maybe 1300 or 1500 in 98. Good luck.
Why does everyone want this guy to get a super rare and expensive ITR ECU just to pass emissions? Unless his state REQUIRES that the ECU match the engine, it doesn't make sense.
You guys got these hanging on trees in the back yard? Got stock in the company that makes them?
Old Mar 12, 2014 | 08:30 PM
ej1b18c1's Avatar
Good luck if you are in CALI!! Unless your paying for it.
Old Mar 13, 2014 | 12:59 AM
tony_2018's Avatar
Fish Twig
Well, if he can run it on a P2P and a P2T than by all means go for it. As long as he doesn't try to dog it out to the emissions station than he should be fine.
Old Mar 13, 2014 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
You'll need to make sure your other EVAP parts are in order as well including the charcoal canister vent purge solenoid and the EVAP purge that generally runs along the fuel rail area. Post your state however as some states you may simply fail the visual. You'll need to run a secondary 02 as well if you haven't already.
Old Mar 13, 2014 | 02:33 AM
doctorake's Avatar
Community Builder
I see what you mean now. I fail to remember that most people are shooting for the cheapest route. I actually went and sourced an expensive ecu for my swap so I had no issues with emissions. Immobilizers can be bypassed also.
Old Mar 13, 2014 | 06:12 AM
B serious's Avatar
Yes....but this makes sense if this is going to be your regular ECU also. If you need an ECU for one day of the year to pass emissions, going out and buying an ITR ECU isn't your best choice. Its pointless.
You wouldn't have trouble with emissions using a P2P or P2T ECU. It would give you the same effect as a USDM P73, which is difficult and expensive to source.
It would be like recommending that someone should go scouring the internet to find an extremely rare set of Rays Engineering wheels that they then have to modify to put them on...for the sole purpose of using them on the one day of the year that they need to roll their shell out of the garage and onto the driveway so they can sweep the floor. Seems like overkill.
Old Mar 13, 2014 | 06:16 AM
apexi_rsx's Avatar
cheapest way would be to get a y8 ecu (no immobilizer)and limp to the station .. it would run the car efficiently enough to get there. don't be cracking vtec.. swap ecu's back when ur done going through the lane...
Old Mar 13, 2014 | 07:00 AM
B serious's Avatar
You have to drive for a day or 2 with the newly installed ECU. Otherwise, it won't be ready for testing. So yes...drive gingerly...but for a couple days. Or use a 99-00 Si ECU if you're worried.
Ideally, you'd want a OBD2A P72 with an adapter...but this all depends on what your state actually lets you get away with.
Old Mar 13, 2014 | 07:59 AM
doctorake's Avatar
Community Builder
Search for the driving cycle to reset your monitors after putting a new ECU in, I got mine all set in about 20 minutes of driving.
Old Mar 13, 2014 | 09:24 AM
B serious's Avatar
Nice. I'll have to check that out
Old Mar 13, 2014 | 09:37 AM
doctorake's Avatar
Community Builder
Also since we don't know which chassis, a P2T will fail in the hatchback, no FTP sensor.
Old Mar 13, 2014 | 10:07 AM
B serious's Avatar
Correct. Unless you find a OBD2A one and use an adapter.
Old Mar 16, 2014 | 04:09 PM
My friend just gave me a p73- a04 ecu.. the usdm type r ecu will it run fine with my 97 itr swap
