Which wires are pwr and grnd ?
Old Mar 5, 2014 | 02:46 AM
mr. Grind's Avatar
Trying to do a tps calibration and trying to verify these wires? Obd0 plug on
Yellow w/ white stripe
Red w/ blue stripe
Green w/ yellow stripe
Old Mar 5, 2014 | 02:59 AM
Freemananana's Avatar
Default Re: Which wires are pwr and grnd ?
I knew I had it somewhere.
Old Mar 5, 2014 | 03:11 AM
mr. Grind's Avatar
Thank u sir. ....for the express deliver.
Old Mar 5, 2014 | 04:45 AM
Not a problem. Hopefully it will help searchers in the future. I found that last year or so on the internet while searching for DPFI to MPFI conversions.
Old Mar 5, 2014 | 07:21 AM
THE GREEN CRX//'s Avatar
tps sensor
Old Mar 5, 2014 | 11:32 AM
mr. Grind's Avatar
Originally Posted by THE GREEN CRX//
tps sensor
yes sir, obd 0 tps. The obd1 plug on has black stripes on the wires but i think
the polarities are the same as the obd 0.
Old Mar 11, 2014 | 10:59 PM
mr. Grind's Avatar
ok guys need ur help. Trying to conduct a tps calib. but when i use the neg probe of the miltimeter on the green wire and the positive probe on the red wire I only get from o to .17 and max throttle at about 1.45.
yes it is on the right MM volt setting
yes the yellow is getting the 5 volt
yes tps i bran new one from blox
yes car isnt started but at ON position
What am i doing wrong?
Old Mar 12, 2014 | 02:58 AM
This is the procedure you are following, right?
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Einhander276
Feb 15, 2011 06:19 PM
thatbluecrx
Feb 17, 2005 09:58 AM
jhmcrx
Dec 25, 2004 05:28 PM
drjondurst
21
Apr 9, 2003 08:37 PM
