FS: B-Series VTEC Engine (Parts) JDM USDM Type-R (ITR, CTR), Si, GS-R
Old Mar 4, 2014 | 06:15 PM
JerseySiPOS's Avatar
Default FS: B-Series VTEC Engine (Parts) JDM USDM Type-R (ITR, CTR), Si, GS-R
Posted are all Honda OEM B-Series VTEC Engine Parts available for JDM USDM Type-R ITR CTR Si and GS-R vehicles. All Items for sale are in 100% good, working condition. Paypal verified and fast shipping with tracking number or local pick up in central NJ.*
Please pm me with your inquiry, even if something is not listed or sold.
JDM Type-R ITR Starter- $80
- quieter than standard b-series starter
VSS (vehicle speed sensor) - $50
Slave Cylinder Assembly - $50
B-SERIES VTEC CAM PULLEYS (GEARS, SPROCKETS) - $50
B-Series VTEC Starter - $SOLD
Oil Pump - $50
- has original oil seal
- add Honda OEM Oil Seal | 91212-PR3-003
- no ckf mounting location (obd1 style)
IAC Valve - $45
- OBD2
- narrow bolt pattern
Injectors - $50
- OBD2
Radiator Hoses - $40
Master Cylinder Hose - $15
Coolant Hose - $10
- thermostat to manifold
Fuel Rail - $50
- honda oem
Clutch - $80
- 60k miles
- great condition
Alternator Brackets - $40
Alternator - SOLD
Jasma Header - $80
- primaries top half
- real jdm diameters
Timing Belt - $30
Timing Tensioner - $30
Engine Temp Sensor - $20
Spark Plug Cables - $35
Post Mount - 40
- 2-bolt
- JDM narrow pattern
PCV Tube - $5
Engine Coolant Temperature (ECT) Sensor - $20
Crank Gear w/ Washers - $40
- OBD1
LSVTEC/B20VTEC Honda PR4 Rods + 81MM P61 Pistons w/ ARP Bolts - $150
Lower Timing Belt Cover - $25
B18/B20 Timing Belt - $30
Crank Gear & Washers - $20
Oil Pump - $50
Water Pump - $35
B16/LS Oil Pan - $50
LSVTEC/B20VTEC/B16A Oil Strainer - $25
LSVTEC/B20VTEC/B16A Windage Tray - $30
Water Pipe - $TBA
Thermostat Housing / Cover - $TBA
Oil Pressure Sender/Sensor - $20
thanks for viewing,
- i.
Old Mar 6, 2014 | 03:53 PM
goldhatch94's Avatar
Default Re: FS: B-Series VTEC Engine (Parts) JDM USDM Type-R (ITR, CTR), Si, GS-R
Very nice for sale thread but nothing I need so bump for you...... Unless you have a ITR muffler for sale
Old Mar 8, 2014 | 07:51 PM
Marvin1985's Avatar
Jasma isn't a brand it's a Jdm emissions tag
Old Mar 9, 2014 | 11:42 AM
^^^ thanks
Old Mar 21, 2014 | 07:05 AM
Genuine Honda
Old Apr 7, 2014 | 01:22 PM
OEM Parts
Old Feb 25, 2015 | 04:45 AM
Honda OEM Turn-Key
Old Feb 25, 2015 | 05:24 AM
ShinsenTuner's Avatar
No Jodas
A lot of good stuff. I don't need anything but all of these items are great for anyone doing an engine rebuild... the odds and ends are definitely hard to come by...
JerseySiPOS
Apr 14, 2015 08:47 PM
JerseySiPOS
Northeast (Sales)
Feb 26, 2014 06:31 PM
_Bug_
Jan 25, 2012 12:41 PM
B16aCRXSi
Northeast (Sales)
Nov 28, 2008 07:32 AM
forksports
Feb 6, 2002 10:19 PM
