Slow/lags/low response JDM d15b y7 head
jdm d15b (obd2 i thinking)
y7 head
timing belt is loose (one side to the other)
bad mpg
po6 ecu
the symptom is... it lags from 1-3k and then at about 3.3-3.5k it starts to pick up, i had adjusted the dizzy and cable (only helped a little) still slow on the highway. Not sure it has the wrong cam gear/timing belt or what. i been driving it all this time since Nov of 2013.
Also when cold it drives fine.. but when it warms up, it starts to lag and then when you step on it, it kinda "bogs" but not really bogging, you can feel the tiny jerk in between, you can hear the engine scream almost like a B series Lol. So anyone know whats wrong?
y7 head
bad mpg
po6 ecu
that timing belt is WAYYY too loose your mechanical timing could be off... id fix that and do a valve adjustment... that is also the wrong cam gear if that is a y7 head. you MUST use a y7 cam gear...
will this be the right cam gear?
my other question is, if the belt skipped a tooth or so, it wouldnt be able to start at all right? i mean, it runs and drives but lags power when you step on it, could it be restriction from the exhaust or something?
its your mechanical timing being off causing it to bog ... yes that is the correct gear it only goes on one way.... it need to skip about 3 or more teeth before running into valve damage... you should be fine once u get the right cam gear on it.
can you verify what head this is and infact a y7?
thatseemslegit
42
Sep 17, 2015 09:07 PM
JDMs1eeper
Aug 15, 2003 10:52 AM
