96 accord, have taken to shop 3x's, still can't fix it...help please
Old Mar 3, 2014 | 05:08 PM
DSMtuneR22's Avatar
Default 96 accord, have taken to shop 3x's, still can't fix it...help please
This is so frustrating, I have taken my 96 accord (4cyl vtec, came out of a 94. Auto, 4 door) to the shop b/c the CEL was on, it read that there was a misfire on cyl #3 and was idling rough.
Runs smooth when I accelerated but when stopping and idle it was rough.
I take it to a new shop.
They replace the distributor, secure vacuum lines and adjust valves.
They charge me $680 for everything.
Tell me its fixed, I drive it to work, no problems. On the way home, the CEL pops up again!!!
Car is running fine without rough idle now though. CEL is still on for the misfire on cly #3 now though.
I called them and they want me to drop it back off.
Why can none of the shops just fix this thing though? Can anyone shed some light on whats causing this issue?
Also if they can't fix it still should I ask for a refund?
Is there a way that I can make them refund me for misdiagnosed work if they refuse?
$600 dollars for a misdiagnose is too much, $100 is a different story though but not the latter.
Thanks!
Old Mar 3, 2014 | 06:03 PM
djkurious's Avatar
Default Re: 96 accord, have taken to shop 3x's, still can't fix it...help please
It seems that you have swapped a 94 OBD1 engine into your 96 OBD2, correct? Also, what else was swapped over?
Old Mar 3, 2014 | 06:10 PM
DSMtuneR22's Avatar
Yes, thats correct. Not sure exactly what else was swapped over, I would think the standard parts that would need to be for the swap.
The engine had been in it and running fine for a 4 months before the CEL came on with the issues.
There was a full long block from the 94 and any parts needed off the old engine due to it having a bad head/block (scarred walls from pistons hitting them).
I can find the list tomorrow for sure and post up exactly what I can find out.
Old Mar 7, 2014 | 08:34 PM
dseriesboulder's Avatar
any update?
mine idles at 300 rpm once it gets warm. am going to clean the iacv, fitv and egr ports this weekend.
Old Mar 7, 2014 | 09:05 PM
1997blackaccord's Avatar
Reply to dseries
That's the update
Don't let this happen to you
https://honda-tech.com/forums/showthread.php?t=3197212
Old Mar 8, 2014 | 03:31 AM
DSMtuneR22's Avatar
Originally Posted by dseriesboulder
any update?
I would check vac hoses, and clean the egr. Should fix or help your situation imo.
I know the car didn't need a whole new distributor after the fact now, b/c they even said it didn't fix the problem BUT after the "vavle" adjustment and securing some mixed vacuum hoses it seemed to help but the main problem was the EGR most likely, until my engine caught on fire.
Old Mar 8, 2014 | 08:36 AM
holy hell.
Old Mar 9, 2014 | 06:12 AM
Known_Offender's Avatar
94 EX EGR port cleaning yesterday. Several glogged ports and large carbon build up. All I can say is wow.....like night and day. I'm a noob, but you might be pleasantly surprised after you clean it.
suckerpunch5
Aug 6, 2014 07:54 PM
DSMtuneR22
Jun 10, 2014 09:17 PM
ramen8161
Nov 6, 2013 04:32 AM
iNCREDiBLYSLOW
May 3, 2007 09:06 AM
cndags
Oct 27, 2005 03:51 AM
