cleaning gasket surface
Old Mar 3, 2014 | 04:07 PM
jimfols's Avatar
Default cleaning gasket surface
Hello, New guy here.
I searched for this but did not come up with anything.
I have not done this for a few years and was hopeful
there might be some new technology for removing head
gasket material from aluminum. Or old technology that works better than what I am using. Permatex spray and
a razor blade.
Cheers,
Jim
Old Mar 4, 2014 | 06:36 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: cleaning gasket surface
a chisel...carefully
oven cleaner helps remove sticky left over gunk
Old Mar 5, 2014 | 03:08 PM
blackeg's Avatar
grey scotchbrite and some brake cleaner. id prolly brake clean first with a shoptowel then use the scotchbrite. after the grey you can use white which is even finer grit. after a minute it works surprisingly well and wont gouge the surface like a razorblade. just use a big sheet and keep light but even pressure as you go back and forth across the surface
Old Mar 6, 2014 | 05:09 AM
KevinEF7's Avatar
permatex gasket remover does work better than oven cleaner and such, I use it to get most of it off, but 300 grit on a sanding block will finish the job and make it perfect. Make sure to use a sanding block, no bare hand shlt
Old Mar 6, 2014 | 06:28 PM
jimfols's Avatar
I'll wrap this up now, thanks for the replies.
I sharpened a heavy duty putty knife till you could shave with it.
I sprayed with Permatex and let it soak over three nights
scraping each day.
I will sand it tomorrow, I have a sanding block.
I feel better now,
Jim
Randysi
11
Oct 24, 2011 07:39 PM
Rickdogg
Sep 13, 2009 05:50 AM
thebleek
10
Mar 14, 2009 09:33 PM
1990si
Jul 19, 2006 01:28 PM
gnar kill
Sep 2, 2005 02:53 PM
