PA B Series Turbo Parts
$100 BNIB ARP B16 head studs, will trade for GSR's
Stock GSR rods, make offer
CX Racing full rad and fan make offer or will trade for half rad.
$250 P-Fab log manifold with 3" down pipe and dump tube, T3 flange 38mm waste gate
B16 tapped oil pan with welded AN fitting make offer
$75 5 point harness (pair) not up to date on.
$800 Borg Warner S400SX 71mm turbo, Vibrant 3" 90 welded to it (off Supra), no shaft play
$650 B Series Sidewinder manifold T4, 44mm Vband wastegate flange with 3" Vband downpipe and Vband dump tube
$100 2 Eagle GSR rods good condition
$150 LS rods with ARP rod bolts and P73 Type-R pistons
$75 Unorthodox Racing cam gears
$200 OBX intake manifold with Q45 throttle body
$350 4 Wiseco 10:1 cpr pistons 85mm 3 used, one brand new, full set of new rings
Eagle Rods for B16, mint only a few thousand miles on them SOLD! Thanks dcmatt
81mm CP pistons "flat top", mint only a few thousand miles on them SOLD! Thanks dcmatt
GSR block, unknown mileage, cylinder walls look good, but one of them catches the fingernail, gonna need bored to 81.5mm, I can get done for extra. Mains are in great shape. SOLD!
GSR crank, great shape, no marks or spun bearings. SOLD!
B16 Block cracked sleeve #2, everything else is mint get it out of here GONE!
B16 crank in great shape, no marks or spun bearings. SOLD!
ARP head studs SOLD! Thanks dcmatt
Used low mile Supertech dual valve springs and Ti Retainers SOLD!
LS Eagle Rods, surface rust from sitting, 3 look good, one needs cleaned off, journals look great SOLD!
I probably have some other things, and I have pictures on my phone. Call or text 724-963-2348. I will have pics posted today with username. Also interested in aftermarket GSR rods and 1000-1200cc injectors. Yes pics were taken with a potato.
user 996328629
Jan 23, 2011 04:23 PM
