95 integra heater not working, replaced resistor
Old Mar 2, 2014 | 06:20 PM
AutoBahn's Avatar
Default 95 integra heater not working, replaced resistor
so my heater motor doesnt work
ive replace the common resistor thinking that was the problem, not the case. I whipped out my multi meter and test for 12v at the 2pin connection and i get nothing on the blue/white wire. I hooked the motor directly to the battery and it runs. i checked for 12V at the relay in the fuse box, i get a reading in pin 1 and pin 4 pin 2 and 3 are 0. just seeing what other steps to take. cause i just dont want to be wasting money throwing new parts at my car.
-how do you test the switch
thank you in advance.
Old Mar 2, 2014 | 06:54 PM
Miguel613ekb18c's Avatar
Default Re: 95 integra heater not working, replaced resistor
Did u check the fuse?
Old Mar 2, 2014 | 07:02 PM
AutoBahn's Avatar
yea sorry checked the fuse
Old Mar 3, 2014 | 07:40 AM
fcm's Avatar
fcm
Old Fart
You have an IM. 94
Old Mar 5, 2014 | 10:43 PM
AutoBahn's Avatar
Originally Posted by fcm
You have an IM. 94
thank you for gettiing back with me. when i jump the relay between constant and switched it runs like it suppose to. im check ing the ground to make sure i have a good ground there
dc4teg95
Jul 27, 2013 02:07 PM
spens 91 Ef
Jul 8, 2009 11:11 PM
polishedturd
Nov 9, 2007 06:22 AM
JapJunkie
Welding / Fabrication
11
Jun 9, 2006 02:06 PM
NatedoggAZ
Dec 3, 2004 02:17 PM
