Fg2 headlight lenses
My headlight lenses are badly discolored and I really can't seem to figure out which product would be best or if I should take it to a shop and have it done due to being scared that I may scratch the paint, some of these fix kits require you to sand the headlight and as I believe this is the best solution if done correctly, I'm not sure if I want to do it myself
its honestly pretty easy to do...
I'll find you the video I watched before doing it on my old EP3.
The key is doing good prep work and having the right product. I suggest you which products to use that will give the best results.
Check in 15 minutes i'll update the post...
Here is the video i watched and did mine... came pretty close to brand new.
Also Chemical Guys products are one the best... You can get painter tape at walmart and sanding paper also just make sure to get the grit as he was using in the video.
But you will need to get either those products or similar products to get it done.
If you have any question don't hesitate to ask!
