Civic suddenly doesn't want to start
Old Mar 2, 2014 | 10:38 AM
ReSpade's Avatar
Default Civic suddenly doesn't want to start
I have a 98' civic ex coupe with d15b swap. Today I drove it to work just fine. When I finished working I tried to start my car and it wont start. It turns over just fine but wont actually start. It cant be the battery or alternator because if it was it wouldn't turn over and I already tried jump starting it. This leads me to believe that its my starter. There is also a slight chance it could be my kill switch because its connected to the fuel injector. If it shorted out it could be whats causing the problem. So what do you guys think? Anything else that could be causing this?
Old Mar 2, 2014 | 10:49 AM
PeelYoMuffinCap's Avatar
Default Re: Civic suddenly doesn't want to start
It could also be your main relay have you checked that yet?
Old Mar 2, 2014 | 11:07 AM
ReSpade's Avatar
Not yet but I will. Thats a good idea. The Honda and Acura relays do go bad often.
Old Mar 2, 2014 | 11:34 AM
Former User's Avatar
Are you saying the starter won't crank the engine?
Old Mar 2, 2014 | 11:42 AM
ReSpade's Avatar
No the engine does crank/turn over it just doesn't start.
Old Mar 2, 2014 | 12:51 PM
No-start basics - listen for the fuel pump priming and check for bright white spark at the plugs.
Old Mar 2, 2014 | 01:46 PM
ZCSpeed rules's Avatar
you more than likely have oil in your spark plugs have you checked?
Old Mar 2, 2014 | 07:14 PM
HondaEm1-00's Avatar
do you have any engine codes?
Old Mar 2, 2014 | 10:47 PM
ReSpade's Avatar
Well me and my friend finally fixed it. It turns out no one was right. My intake was sucking up more air than my engine can use so all we did was adjust how much air can go in.
Old Mar 3, 2014 | 12:11 AM
eghatch9295's Avatar
Stancetard Hate Monger
wtf?
Old Mar 3, 2014 | 08:27 AM
apexi_rsx's Avatar
LMFAO....SMH....
Chev
17
Jun 6, 2018 04:22 AM
JorgeR559
Jun 10, 2014 10:50 AM
s1ngle
10
Aug 19, 2011 06:13 AM
soto2635
Jan 15, 2009 10:44 AM
EJ8 GSR-T
Aug 29, 2008 07:14 PM
