How can I wire my amp?
I own a 1994 Honda Accord LX and am wanting to install an amp. I have already purchased everything and want to know if any other 94 accord owners have found a grommet on the passenger side, or have used a 17ft Power wire and gone through the firewall in an existing grommet on the drivers side. So can I get some help please?
There is a grommet for the OEM foglight harness that's on the left side of the passenger footwell towards the center of the car. Looking from the engine bay it's down low on the firewall straight back/down from the throttle body area.
How far down is it? Where does it come out at? Behind the head unit?
Thank you Muffin Man!
I am going to drill a hole inside of that grommet and place a watertight grommet liek the one you had posted to make sure no water flies into my cabin, especially sine I live in Western washington with all this dang rain, hahah.
Here is a picture of the Grommet inside of my car:Click the image to open in full size.
https://imageshack.com/i/jtpu3zj
If you pull back the top of the passenger side carpet, there will be a velcro piece (Should be) that the carpet attaches to. and behind it is like this black material (Believe it is insulation), there should be a circle shaped "plug." Once you pull that black piece out, the grommet will become visible.
__________________
__________________
Danntek
Dec 30, 2013 05:12 AM
Fobanginvtek
Sep 15, 2012 03:00 PM
