Semi Built K24a2/K20 (Almost complete swap for you)
Almost a complete swap for you to throw in. All you need are mounts
Bought from t57b18 off k20a.org
Motor has 9,000 miles on it
k24a2
12.5 cp 87.5
ib ibeams
coated crank
k20a2 oil pump
k20z1 water pump and oil cooler
accord steel oil pan
k20z1 head and cams
xcessive 58mm intake crome plated
90mm q45 tb with 4 inch intake and velocity stack
id1000s
golden eagle rail
-6 feed line with earls blk fittings
areomotive fpr
hytec rep header
adam west spec engine harness 02-04 rsx type s
kpro
trans
1100 mile k20a2 6 speed trans
comp 6 puck clutch 1100 mile also
oem shifter cables
BINB Hybrid racing shifter cables
Hybrid racing Boltin shifter
96-98 Hasport K swap harnesss
Previous owners car
Everything is ready to be shipped. Local pick up is a plus. Located in central Wisconsin. Will consider trades. $7,000 OBO
k24a2
12.5 cp 87.5
ib ibeams
coated crank
k20a2 oil pump
k20z1 head and cams
id1000s
golden eagle rail
areomotive fpr
hytec rep header
kpro
trans
oem shifter cables
Previous owners car
ek hatchhh
May 12, 2014 10:15 AM
rick_rabies
Mar 29, 2014 01:06 PM
egvtec
Mid-Atlantic (Sales)
10
Sep 29, 2009 05:02 AM
