Suspension & Brakes Theory, alignment, spring rates....
Del Sol Suspension Adjustment Help!!
Old Mar 1, 2014 | 07:39 AM
rhdslosol's Avatar
Default Del Sol Suspension Adjustment Help!!
i just installed the skunk 2 pro-s II coilovers but i am so unhappy i have the springs set as soft as they can go but it bounces so much its uncontrollable idk if its cause of that or cause i have worn lca bushings any help or advice
Old Mar 1, 2014 | 06:56 PM
Runnerdown's Avatar
Default Re: Del Sol Suspension Adjustment Help!!
You can't soften the springs. What is bouncy? What's your ride height at? Inspect the condition of the rest of the suspension, nobody on here can see your bushings etc
Old Mar 1, 2014 | 09:08 PM
DropNotch's Avatar
Just installed the same coilovers with same result initially on my del sol. Give them a few 100 miles and they'll "break in" so to speak. I have 250 miles on mine right now and the ride quality is improving more every day. I didn't mess with the spring preload's though. Only adjusted the ride height so not to scrub. I also have brand new lower control arms, energy suspension bushings, sway bar bushings with blox adjustable endlinks, subframe brace and tie bar, rear upper strut bar, front sway bar bushings replaced with a megan xbrace installed, and three point tower brace. So while at first it was super stiff and bouncy over bridges and such it has started to ride so much better.
Give it time lol.
Old Mar 1, 2014 | 09:11 PM
DropNotch's Avatar
Just re-read your post. If you let the actual springs all the way out, your ride quality is never gonna be good because your shocks are doing all the work. You need to run the collars back up on the springs to give them something to work with.
B88
23
Aug 20, 2016 12:31 PM
london ritzler
Jan 5, 2013 09:37 PM
96johnson
Suspension & Brakes
Apr 14, 2009 09:16 PM
downshift96si
Feb 12, 2007 06:24 AM
