stock fpr question and fuel rail question
Are the b16a2 fpr and ls fpr the same? Can you use a ls one on a b16a2?
When I was getting help doing head gasket..
Putting the fuel line back on the fuel rail my friend pointed out I should have a screw in that end piece(not sure what its called but plastic cap covers it) where it screwed on to put the fuel line on the fuel rail. He had a spare screw that he said that's supose to go in there. When he pit the screw in it just spinning like it was stripped or too small of a screw. He said its stripped inside, I think its wrong screw. What's that end thing called that takes a wrench to unloosen? And is he right, does it effect the fuel delivery? Where can I get a new one if need be?
Ok. I was worried the LS(1.8L) fpr would make my Si(1.6L) run richer.
Now what about that part that screws on the end of the fuel rail? Holds the fuel line and seals it in place? Like i said.. my friend said there's a screw that goes in the middle of it? He said its a $16.00 screw/part. I think he said there's a diaphram/regulator in it? Not exactly sure what he said. Couldn't get ahold of him past few days to find out. Anyone know what that part is called so I can order a new one? I tried looking online what its called but had no luck or didn't phrase my search correct enough.
Thanks for your response B!
16680-PCX-003 DAMPER ASSY., PULSATION it's 40$ from Honda or free from a junk yard there's 2 washers also. 90428-PD6-003 and 16705-PD1-003 they are NOT the same thing one is a gasket the other being a regular 12mm washer.
http://www.ebay.com/itm/HONDA-OEM-16680PCX003-Fuel-System-Damper-/141193085497?pt=Motors_Car_Truck_Parts_Accessories&hash=item20dfc38239&vxp=mtr Damper Essym ??
http://www.ebay.com/itm/Genuine-Honda-Washer-12MM-2-FSC600-ST1300-GL1800-More-90428-PD6-003-NEW-NOS-/221305160455?pt=Motorcycles_Parts_Accessories&hash=item3386d0c307&vxp=mtr <washers, I thought they were copper? The ones I seen were copper.
Also whats the 3rd one for?(16705-PD1-003)
I'm having a horrible time looking for these parts. I'm usually good at shopping for what I need, but then again ask what brand to get from other members.
If its not any hassle help me shop and find lowest prices? or those first two links good?
Thanks B! Always a great help!
Unless used they're not going to be cheaper you could try a part store but I've never had luck with things like that from part stores. the last part number is a washer too I think it's just a bit different then the other. OEM Honda is the only 100% perfect fit.
B18EG6
Jan 8, 2003 12:24 AM
