Ground control coilovers 330F/600R
so i bought a used set of these, and from what i converted
one set (rears i think) is 6 inches long with 600LB weight
one set(fronts i think) is 7.87 inches long with 330LB weight
is 330F/600R ok?
or should i use the 6in 600LB F / 7.87in 330LB R
wat you guys think?
itll be on a D16y7/8 98 LX sedan with future plans of Turbo
is 330F/600R ok?
wat you guys think?
that's an odd set up choice imo I guess for street driving it doesn't matter as much for the handling as oppose to time attack/auto x. I'd leave the rears at 600 maybe get some 500+ fronts tho.
so i called GC directly, and i guess its 8inches long, 2.5 diameter, 340LB spring
i guess ima just put the 340 F / 600 R
itll be for street driving with lots of heavy Equipment in the trunk so i think itll be ok
for what i apdi, 80 BUCKS! i aint complainin!!
Cool Cool Island Breezes. BOY-EE
600R? Back surgery costs more than $80.
What shocks are you planning to use? This is going to be awful lol.
$80 to ruin ride and handling? Leaving it alone is free. That's a $80 savings.
"Hey...I wasn't hungry, but that spoiled meat was only $2!" is an example of a bad decision as well.
well its going on Koni yellow struts
i mean im having all my tools in the trunk and spare tire
along with my sub/amp sub box with sub alone is weighed at 40-80 LBS lol
tools weigh about 30-40lb
spare is what? 10-15?
hopefully itll be ok??
sell them it's not the fact that they're 600 but more so you'll be running 350 in the front that's super unbalanced typically the rear is softer...
last question then lol
would it be better for 600 F / 340 R??
if thats still not ok, i guess i will sell them
e:
im about to order 96-00 koni yellows from my guy for super deals
e:
The back of a civic coupe weighs about 515LB per corner. Just for reference.
I wouldn't use that spring combo. You can always buy 2 more 380LB springs. They're cheap. 350F and 380R is a great combo. Sell the 600LB springs to someone who has 500LB fronts.
You're going to blow those semi expensive Konis using a 600LB spring. You need better damping at 600lbs/in. I think Konis max out at 500...and that seems sketchy.
just called gc, its 140 total with shipping for 2 springs, so i will figure something out.
