For Sale: T3/T4 Turbo + Inline Pro Manifold + FREE 60mm Greddy EGT!
I have for sale a T3/T4e Garrett Turbo with .60 a/r Compressor, .63 a/r exhuast housing. Not sure about internal specs but it spools up at 2,800 RPM in my b20 and made full 12.5 PSI at 3,800. It cost me $600 brand new from Garrett but I only used it for 2,000 miles. It is also SEMI polished. Not fully polished, but semi polished which took me 3 hours.
Also have a polished (took me like 8 hours!) Inline Pro Stainless Steel Turbo manifold However it turned purple (thats how SS reacts to heat
). Retails at $500
Also I have a BRAND NEW EGT 60mm Electronic Gauge with warning from Greddy that cost me $270. NEVER USED! Never exposed to heat yet
. The probe is already tapped (Took me 2 hours, and broke 3 bits) to the inline Pro manifold so I will give this away at no charge. Only problem is, I cut one of the wires and misplaced it somewhere and it is missing the harness, however you can ghetto rewire it. It is only 2 wires! So this will be a FREE item because of that.
I want $1,000 for all 3 items! All you need is a downpipe, charge pipes, wastegate, bov, oil lines, and fuel management and you can have a complete turbo kit for cheap
). Retails at $500Also I have a BRAND NEW EGT 60mm Electronic Gauge with warning from Greddy that cost me $270. NEVER USED! Never exposed to heat yet
. The probe is already tapped (Took me 2 hours, and broke 3 bits) to the inline Pro manifold so I will give this away at no charge. Only problem is, I cut one of the wires and misplaced it somewhere and it is missing the harness, however you can ghetto rewire it. It is only 2 wires! So this will be a FREE item because of that.I want $1,000 for all 3 items! All you need is a downpipe, charge pipes, wastegate, bov, oil lines, and fuel management and you can have a complete turbo kit for cheap
Here are some pics, it's a pretty big slug! And these are old pics without the EGT Probe tapped. The EGT Probe is tapped to the 3rd runner, the hottest one. Also the manifold looks a bit darker then that. More purpleish'.
Ri5e
Oct 29, 2002 03:16 PM
