How to adjust door to body tightness? 2000 EJ8
Old Feb 26, 2014 | 02:29 PM
Skip01's Avatar
Default How to adjust door to body tightness? 2000 EJ8
Is there a way first off on a 2000 EX 2dr?
I searched and i some say you can adjust the door locks...but i took door panel off and loosened the door lock bolts and i couldnt get it too move...looks like the screws only go one spot in a lil dimple on door
Im getting a lil leak from top of door and it collects n drips down til it hits the tweeter on door panel and than drips down..not much but enough too annoy me after a hard rain
Carpet doesnt get wet so it isnt a huge issue at the moment.
But i bought a new door weather stripping from Honda....see if that helps...but it seems like when i unlock my doors and just barely touch handle itll open without much resistance.
Weird too explain, but it feels like it opens just soooo easy and not like passenger door seems like it has too unhook from door latch.
So is there any way too make the door lock or make it latch tighter?
Thanks
Old Feb 26, 2014 | 05:26 PM
Marvin1985's Avatar
Default Re: How to adjust door to body tightness? 2000 EJ8
Sagging door adjust it up front
Old Feb 26, 2014 | 05:34 PM
Skip01's Avatar
By the hinges?
It doesn't look out of align... But I'll check it out
How can u adjust the front of door?
Old Feb 26, 2014 | 06:09 PM
tony_2018's Avatar
Fish Twig
I usually follow the lines of the car, check both sides to make sure the clearance is exact. Same goes for fenders, hood and trunk. Yeah I get **** with it.
Old Feb 26, 2014 | 06:20 PM
Skip01's Avatar
You from New Orleans...lets get a lil alignment meet going lol
Old Feb 26, 2014 | 06:53 PM
crazyhouse2011's Avatar
HOW DO YOU DO THAT? LOOSEN THE BOLTS, have somebody hold the door the right height, AND TIGHTEN? AND THEN RINSE AND REPEAT TO GET IT JUST RIGHT?
Old Feb 26, 2014 | 09:58 PM
Marvin1985's Avatar
Yes!
Old Feb 27, 2014 | 06:18 AM
Skip01's Avatar
How can you adjust it in and out though... Not just alignment
Old Feb 27, 2014 | 06:37 AM
kyden's Avatar
adjustment of the back of the door is done at the striker, not the door itself.
if the bottom of the door is aligned with the body, you might have to physically tweak the top of the door.
Old Feb 27, 2014 | 08:02 AM
Skip01's Avatar
So you can adjust the striker, the latch door catches to close on the body?
I'll look at that too
Old Feb 27, 2014 | 09:02 AM
kyden's Avatar
yes, where it mounts on the body is slotted.
Old Feb 27, 2014 | 09:11 AM
Skip01's Avatar
Awesome...ill look and move it inwards see if that does anything
mataliandy
Jul 12, 2010 06:24 PM
DTMkarnage
Jun 15, 2010 01:02 AM
suhteevin
Jan 6, 2009 09:04 PM
98itR484
May 22, 2002 09:20 PM
