2000 civic Si CEL, high idle, jerky
My Si engine just got a bottem end rebuild and now it's acting up. I get the code p0505, my idle is around 1500 and will jump to 2000 then back down to 1500 and then back up. Then when I let off the accelerator it just completely cuts off power causing it to be jerky. Any thoughts?
P0505 - IACV malfunction.
Have you inspected your vehicle to ensure that all vacuum hoses are connected securely, and free of leaks? This is the most common issue from my experience.
No. In this case it might be best to ensure that all vacuum lines are connected first. If they are, double check that they are secure and then spray the vacuum lines down with soapy water and watch for bubbles.
And yes, this would be starting from the Intake manifold, which is located by the fire wall as shown in the diagram.
just to further what everyone else is saying vacuum leaks are a great place to check. but to add to what your post stated. if you had block rebuilt etc i assume the head would have been removed. personally sounds like possibly forgot a gasket/bad gasket if reused etc. throttle body, tps. etc check for air leaks etc around these portions. iacv throwing a code then try to clean etc.
ya i am not a hundred percent if anyone can chime in but while you are driving and car is warmed up. once you turn off maybe around 3 or 4 minutes later restart is idle down or still rev hunting. i also have a si and been battling a obd1 to obd2 conversion to try in get back to stock etc. was battling the same thing. was the tps sensor installed correctly. not to question your skill but the simple things is what kills us.
Remove the air intake system. Start engine. Cover the top of the TB with the palm of your hand and hold it there. Are you able to kill the engine?
If so, restart engine. Use you finger to cover the hole inside the TB leading to the IACV. Does covering the hole make the idle speed drop and the idle surging stop?
I did that and it just lowered my idle speed but I could hear the surging still happen just at a lower speed. I couldn't make the car die by covering the throttle body with my hand though
edscar
May 25, 2017 07:58 PM
freedomx101
23
Apr 11, 2008 11:16 PM
If all checks out, let us know.
