91 Civic/D16Z6 swap - at a certain point on my throttle, the car just cuts
So I have a 91 ef hatch with a d16z6 swap. Just put the swap in and now when I drive, at a certain point on my throttle the car just cuts as if i took my foot completely off the gas. Its not. So when i drive, unless im going up hill, i have to constantly be accelerating. I cant keep it at a certain speed because it cuts. Its a consistent spot that it cuts every time. Anyone know what this might be?? I was thinking throttle position sensor but im not sure. Just a guess. PLEASE HELP!! Thanks
Could be the TPS I suppose. Are you throwing any CEL codes? You are running OBD1 right? You didn't mismatch any wires, or not switch the distributor/ECU or something along those lines, did ya?
Try switching the 2 outside wires on the tps plug. When I converted my first hatchback to obd-1 back in 2008 I had the same problem. I just switched the 2 wires and problem was fixed.
This is done when swapping from DPFI to MPFI. If you haven't done this, that's it for sure!
In the future, create a thread title that summarizes the tech problem. Title edited.
"NEED HELP ASAP!" is not adequate and may cause your thread to be closed.
cannouu
Engine Management and Tuning
Mar 31, 2014 11:58 AM
crooked muffler
Aug 3, 2004 09:23 PM
