exhaust leak?? 96 honda accord lx at
Ok so all of sudden when I start my car it makes a screech noise for two secs and then comes the rough idle. Ive sort of always felt this rough idle when my car is trying to tell me its time for a tune up so I thought nothing of it. However, I put the car in drive and as I accelerate I hear my exhaust yelling at me. It sounds very loud and almost feels like its struggling to keep power. (Like a clogged sound) Also, ive noticed a faint smell of gas or fumes. I believe its a leak in my exhaust. What do you guys think?*Btw, I had my muffler replaced a year ago but I dont think that is relative to this problem.PLZ HELP IM TRYING TO AVOID SPENDING CASH FOR A CHECKUP
I've done the hard work for you....just click here> http://lmgtfy.com/?q=1996+honda+acco...ytic+converter
replace your cat but help me if i am wrong but 96 obd2? wouldnt there be 2 02 sensors one showing effiency of cat? or one after the cat comunicating with ecu should be throwing a code? do you have a check engine light on? i would check if there is a potato in the pipe lol
^Like this guy lol no homo. Funny ****.
Pretty sure there two O2 sensors on that vehicle.
Start with either a new catalytic converter or "gut" your current one...if you gut your "cat" you may need to run a defouler to keep the "cel" off.
Your stock Catalytic Converter unbolts from the OEM system unless its been replaced w a "welded" unit. You will need new gaskets on both the inlet and outlet when you reinstall.
bigsnorlax
Sep 6, 2008 03:17 PM
