Changing front compliance bushing to spherical.
I have ordered Kingpin machine spherical front compliance bearings to replace the OEM ones, as the were made for NVH reduction. My question is will i need to remove the arm that goes to the f-lca to the compliance bearing ? any one replaced these on their cars in general ?. (I know spherical's are short lived if you street drive the car)
Cool Cool Island Breezes. BOY-EE
The bushings slide off....unless they're rusted.
You remove the 19mm nut. The compliance bushings then come off.
ok I'm just assuming they're a tighter fit then the oem and may need to be pressed in, the stock compliance are horribly soft even from the factory.
The stock bushing has a metal sleeve that attaches to the LCA mounting point. The metal is what it slides on.
oresama
Apr 15, 2012 07:54 PM
Bill_Ee9
16
Mar 4, 2007 03:11 PM
