2001 acura Integra no start
Old Feb 24, 2014 | 07:31 PM
Johnoolo's Avatar
Default 2001 acura Integra no start
when i was leaving school today i got into my car pushed the clutch in and turned the key nothing happened the radiator fan turned on an started spinning. I was able to push start it but when i turn the key nothing happens, but then later i could start the car with the key and now the key wont start the car but i can push start it. when i was driving like this my temperature gauge was jumping around a lot. im leaning towards the starter or the ignition switch any ideas
Old Feb 25, 2014 | 05:33 AM
eman96's Avatar
Default Re: 2001 acura Integra no start
Does it turn over/crank?
Old Feb 25, 2014 | 07:06 AM
fcm's Avatar
fcm
Old Fart
Start by redoing your main grounds, [batt. to chassis/chassis to engine/VC to rad support/thermostat grounds].
Then next time, [if above does not solve problem] it will not crank do a bypass jump to narrow down the problem.
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
Old Feb 25, 2014 | 09:59 AM
Johnoolo's Avatar
sometimes it will turn over and crank most of the time it does nothing im going to do the bypass jump tonight and inform you my results.
mr.mengo
Apr 1, 2014 07:35 PM
EFS463
Aug 14, 2013 05:10 PM
poptik
Nov 25, 2010 07:11 AM
Chiito4
Jul 30, 2009 08:40 PM
makinoracer
Jul 19, 2005 06:07 PM
